Does a well have to be vented?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Shooter45, Jun 24, 2011.
  1. Shooter45
    Shooter45 New Member
    Mar 9, 2011
    MS
    Our new well is not vented other than the hole where the wires go through which is open for anything to crawl through and down the well. Any suggestions? If it does not have to be vented I'll just silicone it up.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Without a vent the well can be under a vaccuum which can draw critters in from other places. Silion the wires but put in a vent with a screen pointed down using two elbows.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Whether or not the well would benefit from being vented depends on the well. A well casing can act as a storage reservoir and the pump may draw it down faster than the well can produce. The well can then recover between pump cycles. Sealing the top of the well could cause water to be forced at greater GPM from the bottom and could in some cases bring up sand.
  5. Shooter45
    Mar 9, 2011
    MS
    Thanks. Bought the pipe and vented it today. Also siliconed the wires outlet.
Similar Threads: Does vented
Pumps and Tanks Well Forum & Blog. Water is life. Does anyone make/sell 6.5inch well seals? Sep 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump does come on and runs until pressure gauge reads 70. Aug 8, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump doesn't seem to pull water Jul 25, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Use water outside: water Stops - Inside water does not May 8, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Does this make sense? Jan 8, 2016
