dock water line
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by deniseendo, May 20, 2009.
  1. deniseendo
    deniseendo New Member
    May 20, 2009
    registered nurse
    charleston, sc
    Hi everyone! Can someone please tell me the best pipe to use on my dock. I know some pipe are not well suited outdoors due to UV rays. What type do you all reccommend?
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    What I've seen typically down here is sch. 40 buried up to the seawall then transition to type L copper for the dock runs.
    I've also seen the transition usually with a yard hydrant then regular garden hose run along the dock. If the garden hose fails either by "natural" means or if something hits/tears it the fix is quite easy.
    Also, depending on your water vs. dock height and how your existing water is set up you may want to consider a backflow preventor.
  4. hj
    pipe
    UV will damage almost every type of plastic pipe, But, a coat of latex paint is usually adequate to prevent it.
  5. jimbo
    jimbo Plumber
    "regular" garden hose is not NSF rated, and not allowed for potable water. You can buy NSF hose at a marine supply, and even some garden centers. It just costs a lot more~
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Around here the most commonly used tubing on docks is black polyethelene as the docks move up and down with the tide and yes, backflow prevention is needed.
  7. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    Around here we have huge fluctuations in lake water level. Most docks do not have water supplies for drinking/cooking but for washing boats and that sort of thing.. thus, not intended for a potable water supply. If you put copper to the dock and it is visible it's not going to be there next weekend 'cause some jack rabbit is gonna steal it! The way I've done this is to use hangers to attach PVC to the underside of walkways to protect it from the sun's u.v. rays. On each end I put a male garden hose bib or hose pipe adapter of some kind. To make the jump across the hinge between land and walkway and again between the dock and walkway I use a braided stainless steel washing machine hose and give it plenty of slack. Servicing vacation homes on water fronts is my particular specialty. I'll also add a tee with a ball valve at the dock's lowest point to drain all the pipes so they won't freeze in the winter. If you want to add an anti siphon device at the connection to the water supply for safety or to satisfy health regulations then that's a very good idea too.
  8. SacCity
    SacCity In the Trades
    Mar 14, 2011
    Sacramento, CA
    I would use schedule 80 PVC it is dark gray and rated for sun exposure, the fittings are about a cost equivalent of copper, but the pipe is not bad,
    On a one inch water line pipe was abut 50 cents a foot and the fittings seemed to be about $4 each on average
    Michael
Similar Threads: dock water
Plumbing Forum, Professional & DIY Advice Downhill dock water line Feb 10, 2014
Plumbing Forum, Professional & DIY Advice Plumbing for a gas water heater Yesterday at 8:22 PM
Plumbing Forum, Professional & DIY Advice Occasionally hearing water running through vent stack, but no water is running. Yesterday at 6:13 AM
Plumbing Forum, Professional & DIY Advice It's Hot! Drink some more water. Yesterday at 3:38 AM
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Tuesday at 6:03 AM
