Do you think a 3-1/2" vent stack is moronic? I do.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hawkeyeerik, Jul 27, 2009.
  1. hawkeyeerik
    hawkeyeerik New Member
    Jul 27, 2009
    My vent stack roof boot is leaking. I'm guessing it has something to do with a 3" boot over a 3-1/2" vent stack.
    [​IMG]
    Is my roofer a moron or the plumber? I'm guessing the latter since boots come in 3" and in 4" and nothing in 3-1/2" that 10 mins of Google can find... I wonder what you think.
    I'm thinking I need to cut it off in the attic and make it 3". 4" if the city says so. Not a big deal... I just hate fixing other peoples' stupidity, and I think there was some involved.
    Also: separate rant. Anders Lign compression fittings (the ones with the integrated sleeve in the compression nut) are crap, and it's all the home stores sell now. 4 for 4, two different boxes of type-L 3/8" soft copper tube, all leaked. Going back to John Guest fittings
    Thanks for letting me vent
    Ha ha, get it?
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    So the inside diameter of that stack is 3 ½"? The O.D. of standard 3" PVC Schedule 40 PVC pipe is 3 ½" but the inside is 3". So apparently its the wrong roof flashing.
  4. hawkeyeerik
    Jul 27, 2009
    Amazing
    SewerRatz, you are the reason I posted this. Sometimes you just need slapped by a stranger. It IS a 3" pipe.
    I still think a 3-1/2" vent stack would be moronic. Thinking 3-1/2" OD = 3-1/2" Sch 40 is more moronic. Thank you sir. Maybe the sewer gas made me delusional.
  5. SewerRatz
    Nov 20, 2008
    Chicago, IL
    *chuckles* It is a common mistake lots of people make.
  6. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    VTR's here typically have a lead wrap flashed into the roof.
    Similar to this.
    [​IMG]
  7. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    And it also keeps the pvc from direct light.
  8. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    What it is is whoever installed the flange didn't realize that they are supposed to be tight, real tight and it takes a bit of push to get the pipe through so they slit it instead. Find the slitter and place the blame. Oh, yes you have to replace it now, it will leak forever.
  9. hj
    vent
    The "moronic" thing about a 3 1/2" vent would be the time and expense of trying to find ANY pipe or fittings in that size. You have a 3" vent pipe with a flashing that was installed by a moron. Unless the sleeve fits tightly around the pipe there is absolutely NO WAY it is not going to leak, unless you live in the middle of the Sahara Desert where it seldom, if ever, rains. The plumber may have furnished the flashing, but the roofer installed it while shingling. If he snipped it to install it, he was a moron, and if it was already cut and he installed it anyway, he was still a moron.
  10. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    Thanks for reminding me
    I need to put a flashing in for the future 3" stack on the new roof
  11. hj
    flashing
    Put a piece of pipe through it so that it is sealed. You can connect to the pipe later.
  12. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    Hard to believe that someone is still using lead flashings on vents, thats pretty close to passe.
  13. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Note that if you carefully remove the "rubber" from a new, similar flashing, slide it down onto the pipe and adhere it to the cut rubber with, say, silicone, it will be raintight until you get around to replacing the full flashing, without any rush. It could last for years.
  14. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Still see them quite a bit down here. I also see alot of full rubber boots but whatever, I'm sure the OP got the point.
  15. hj
    flashing
    Here they are almost all metal cones, other than lead when tile roofs are installed.
  16. hawkeyeerik
    Jul 27, 2009
    Thank you all
    Thank you all for your input and commentary. This is how it is going to look until the fall.
    [​IMG]
    Questionable aesthetics,... yes. Patience to care,... depleted. House feels like it's falling apart faster than I can put it back together these days :D
  17. hawkeyeerik
    Jul 27, 2009
    rain collar
    Thanks, our home stores don't carry them and I can't make it to the plumbers' supply during the day, so at first I made them myself.
    [​IMG]
    But, I was a moron and made them with 4" boots when I needed 3" so I whipped them in the trash furiously. When I bought the 3" boots I was lazy and just slipped the whole flashing right over.
    Getting a new roof in the fall... it was hard to care at that point :rolleyes:
  18. hawkeyeerik
    Jul 27, 2009
    oh
    Oh, you meant as a permanent replacement. I just figured all new flashings with the new roof so I was just trying to stop the leak for now. I saw the Oatey rings online but thought they were meant to slip over and act as a rain collar, not as a permanent repair. Thanks for the tip.
Similar Threads: 3-1/2 vent
Plumbing Forum, Professional & DIY Advice Venting madness: Adding a second washer, moving one. Thursday at 7:43 PM
Plumbing Forum, Professional & DIY Advice Shower venting details/ dry run Wednesday at 7:14 PM
Plumbing Forum, Professional & DIY Advice Dumb question: will a lateral vent prevent a backup event inside the home? Wednesday at 6:52 PM
Plumbing Forum, Professional & DIY Advice Correct wet vent design??? Monday at 4:47 PM
Plumbing Forum, Professional & DIY Advice Bathroom planning advice (venting questions primarily) Feb 12, 2017
