Do I Need Draino?
Discussion in 'Drain Cleaning' started by xroad, Jan 6, 2009.
  1. xroad
    xroad New Member
    Oct 12, 2008
    My bath room sink has been draining slower and slower. I took a peek down the drain and saw lots of black cruds. Possibly they are build ups from soap, tooth paste, and snot. I do not have this problem with my bath tub. When I replace my bath tub last year, I looked at the drain pipe and it was clean. When I replaced my sink down pipe last year, it has the same build up. A year has gone by, and it is starting to clog again. What can I use to clear this?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Do not use Drano or any other chemical. You have a clog and the only way to properly clear it is to have a plumber who does not have Roto in his company name clear it.
  4. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Not draino
    This will also clean your pipes good but needs to be used on a regular basis:
    [​IMG]
  5. gardner
    gardner DIY Senior Member
    Apr 2, 2007
    Ontario
  6. hj
    drain
    The ZipIt shown above is all you need to clear the drain below the sink, (my wife has been after me to use ours for the last couple of days). If there is a stoppage elsewhere then you need a snake.
  7. tlarson
    tlarson Member
    Aug 18, 2007
    Oregon
    Using a plumber is not the "ONLY" way to properly clear it. This sounds like a typical vanity clog, and I've cleaned many of them by simply removing the trap, tail piece, etc and then removing the hair and other build up. It may require replacing a seal or two, and needs to be done carefully, but it can be done by a DIY'er.
  8. dave36
    dave36 In the Trades
    Apr 11, 2012
    plumbing/heating contractor
    Philadelphia
    There are more natural ways to clean your pipes. Using harsh chemicals is never a good idea.
  9. Clog Pro
    Clog Pro New Member
    Apr 4, 2012
    Vancouver, WA
    I agree. It's much better to use environmentally safe and natural drain cleaning liquids rather than the normal Draino liquid from a grocery store.
  10. Dustinmorris8
    Dustinmorris8 Newmax Plumbing
    Mar 14, 2013
    Cincinnati
    From my experience over time, using chemicals causes pinhole leaks in pipes and becomes a much bigger problem. Snakes help but if it is a deep clog, I would go with a drain cleaning job to be on the safe side.
  11. Gary Swart
    Sep 1, 2004
    Yakima WA
    My comment about the need for a plumber was predicated on the assumption that the main drain was clogged. Certainly, removing the trap and cleaning out the hair collection does not require a professional.
Similar Threads: Need Draino
Drain Cleaning Need ideas on unclogging between tub and main septic line. Jan 16, 2015
Drain Cleaning Need Help Identifying How To Clear A Section Of 4" Sewer Line In My Basement Sep 29, 2012
Drain Cleaning Bio-Clean "how to" instructions needed, please! Mar 30, 2012
Drain Cleaning I don't want to kick out my tenant... main line needs repair Feb 26, 2012
Drain Cleaning $10K in damage so far...HELP NEEDED PLEASE! Jul 19, 2011
