Do I need a flexible copper fitting where these lines connect
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by templar2b1ask1, Oct 20, 2005.
  1. templar2b1ask1
    templar2b1ask1 New Member
    Oct 20, 2005
    I trying to finish installing a Central Boiler wood fired heating unit.
    Visit their website:
    http://www.centralboiler.com/
    I am concerned about what will happen when the hot water moves through the insulated underground PEX line to the hard copper connection in the basement to the hot water tank & heat exchanger in the forced air furnace.
    My questions are:
    1. Do I need a flexible copper fitting where these lines connect at the transition?
    2. Should I use a copper "Fast/Flex" connector as manufactured by Slant/Fin, Greenvale, N.Y. 11546 Phone 516-484-2600?
    There is nothing on their website http://www.slantfin.com/contact.html
    3. Is there another product available which gives the same flexible transition from hard copper to plastic PEX pipe?
    Thank you for any advice!
    Jerry Gibbons
    Dowling, MI
Similar Threads: need flexible
Plumbing Forum, Professional & DIY Advice Need Help Connecting Two Sections of Flexible PVC Jul 3, 2011
Plumbing Forum, Professional & DIY Advice Need to modify bathroom piping before inspection Tuesday at 4:34 AM
Plumbing Forum, Professional & DIY Advice Need advice on replacing toilet flange Mar 18, 2017
Plumbing Forum, Professional & DIY Advice Do I Need To Replace This Pipe Soon? Mar 15, 2017
Plumbing Forum, Professional & DIY Advice Need help with Pump Pressure switch shutoff Mar 15, 2017
