Do gas powered tankless heaters have the “flow control’ of “thermostatic†feature?
Discussion in 'Tankless Water Heater Forum' started by Abraham, Jun 29, 2010.
  1. Abraham
    Abraham New Member
    Jun 29, 2010
    Atlanta, Ga
    Hello to all, I am a first timer and after combing around a bit I have decided that this community seems quite a fitting venue for my predicament.
    I have a rental property that I have been renovating for quite some time now and in the basement there are plans for a new kitchen and full bathroom. The bathroom and kitchen are to be directly adjacent to one another.
    I want to have a separate or point of use water heating system to service the basement. I am leaning towards a tankless unit. I discussed the situation with a few local servicemen and I have received varying info.
    All of them have suggested a unit with a flow rate capacity in the 4 to 5 GPM range. However some have suggested that I go with an electric powered unit, mainly b/c of a “flow control†feature that supposedly modulates the varying incoming flow rate in order to ensure an accurate out put temperature.
    However others have suggested I go with a natural gas powered unit b/c of the additional efficiency and the fact that natural gas is available.
    The “flow control†feature described to me seems very fitting for the type of application, and only a few electrical additions will be required since the basement was remodeled with a separate 200 amp circuit panel. But efficiency and comfort are one of the main selling points I wish to use when renting the property in the future, so I don’t want to rule out a gas powered tankless unit for the basement.
    My question(s) is;
    Does anyone know if gas powered models come equipped with similar “flow control†features? Or is this type of flow rate and/or power supply modulation unattainable with gas powered units?
    When I have asked I received several confusing answers from several pros.
Similar Threads: powered tankless
Tankless Water Heater Forum Tankless water heater with a small tank? Feb 3, 2017
Tankless Water Heater Forum Bosch us12 tankless Jan 27, 2017
Tankless Water Heater Forum Tankless issues Jan 24, 2017
Tankless Water Heater Forum Enough gas supply to install tankless? Jan 21, 2017
Tankless Water Heater Forum Considering two dual-tankless options - feedback requested Dec 31, 2016
