Do all metal boxes need screw-in clamps?
Discussion in 'Electrical Forum discussion & Blog' started by Verdeboy, Sep 20, 2007.
  1. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    I spent about $8.00 on a metal ceiling fan box, but it didn't come with any screw-in clamps. Does that mean it is not required, or do I have to supply my own? The Romex cable is stapled up to a few inches of the opening in the box.
    Is a screw-in clamp required whenever a cable enters or leaves any kind of metal box--be it for a light switch, outlet, light fixture, or junction box?
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    SOME sort of clamp IS required. Whether it be integral to the box or separate.
    With a metal box something needs to secure and protect it.
  4. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    Far as I know... yes.
    At less than a dollar apiece, why's it matter?
    Must be even less, where you are, since you got the fan box for 8 - fan box costs almost 20 up here.
    edit: dang, I just answered an electrical question from Eric, didn't I?
  5. Verdeboy
    Jun 12, 2006
    See, that wasn't so bad. :)
    More to come. I like doing electrical stuff. It's nice, clean work (unlike other trades I can think of) and you get to use your brain a lot.
  6. snafflekid
    snafflekid Electrical Engineer
    Apr 23, 2007
    Electrical Engineer
    did you buy a handybox or something similar that has knockouts for those threaded nipples?
  7. kd
    kd New Member
    Dec 11, 2006
    Most jurisdictions allow the use of plastic grommets, bushings, if you staple within 8 inches of the box.
Similar Threads: metal boxes
Electrical Forum discussion & Blog PVC vs Metal (Bell) boxes Nov 15, 2011
Electrical Forum discussion & Blog plastic or metal junction boxes Jan 7, 2009
Electrical Forum discussion & Blog Proper grounding of 3-wire submersible pump in metal well casing Jan 23, 2017
Electrical Forum discussion & Blog Using Madison Clips with new work metal box Mar 14, 2015
Electrical Forum discussion & Blog Using grounding bar inside 3-gang metal outlet box Mar 14, 2014
