Dmw Chart
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dax321, Oct 27, 2006.
  1. dax321
    dax321 New Member
    Oct 24, 2006
    transportation
    Miami
    DWV Chart
    Please Review
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Each fixture needs it's own vent. I don't know any inspector that would pass this. Your traps will siphon out.
  4. hj
    vent
    Your drains are near a vent, but they are not vented. Throw that drawing away, and make a new one. There is nothing about that one that will work, and in some areas you cannot even connect a drain line to a cleanout.
  5. jimbo
    jimbo Plumber
    San Diego, CA
    I suspect that your original plumbing is not really just like you have drawn. Others have pointed out that venting is much more complicated than shown on this drawing. As drawn, nothing is to code.
  6. dax321
    dax321 New Member
    Oct 24, 2006
    transportation
    Miami
    Thanks For The Feedback!
    Thanks ALOT for all the feedback.. I REALLY DO APPRICATE IT!
    I will submit a NEW drawing.. PLEASE comment.
    Thanks
    Don
  7. dax321
    dax321 New Member
    Oct 24, 2006
    transportation
    Miami
    New Chart- Please Comment.. Thanks
    New Chart- Please Comment.. Thanks-->i Hope This One Looks Better
    Thanks
    Don
  8. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    lowered floor OK
    here are some things I feel comfortable commenting on.
    1. You maybe don't have to build the floor up. As shown below. The shower p-trap might not get in the way. The toilet (which has a p trap inside it) needs room for its drain. Another thread i commented on in the Toilet forum had the same problem of needing to sit an inch high so the drain would connnect.
    2. The top part of the vent can be built as shown below. No need to run separate pipes.
    3. The washer drain connects into the vent pipe first, before connecting to the drain.
    How you get the vent through your building 'envelope' (i.e. to the outside) is not something i can comment on.
    I am not a plumber. In my municipality, and in my high-rise concrete building, I wouldn't need as much venting as you have shown - with four vents for four drains/fixtures. I am not a plumber.
    david
  9. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    I need to hook up with a computer nerd and created a plumbing software that is the simplest to use but creates the best drawings whether isometic or plain stick drawing.
    Idea above is a future retirement plan, screw saving money.
    I've been directed to sites that already offer that but the way they are designed.......you have to be a computer nerd to use it.
    We need simplicity.
  10. dax321
    dax321 New Member
    Oct 24, 2006
    transportation
    Miami
    RUGGED->Thanks for your help
    RUGGED->Thanks for your help:mad:
  11. dax321
    dax321 New Member
    Oct 24, 2006
    transportation
    Miami
  12. Dunbar Plumbing
    Apr 18, 2005
    Your welcome,
    I'm glad I was able to help you out.
    I got macular degeneration too.
Similar Threads: Chart
Plumbing Forum, Professional & DIY Advice Uncharted territory - clay to PVC May 22, 2010
Plumbing Forum, Professional & DIY Advice City Service Pipe Diameter Chart Nov 24, 2007
Plumbing Forum, Professional & DIY Advice Dwv Chart #3--please Comment Oct 27, 2006
