Hi - I have 120 psi supply pressure to my home and no pressure regulator installed. When I turn on both showers and 3 sinks the pressure only drops to 85 then climbs immediately back to 120. I want to try to install the regulator myself as my budget is really tight. I have a very small water meter box in my yard that wont accommodate the regulator to be installed on the downstream side of the meter in the round. My home is on a slab with no crawlspace and the main supply enters the home through a wall in my garage with the first fixture being a garden home spigot.
My question is: is it advisable to install the regulator in the wall cavity before the garden hose spigot? I am thinking of cutting an access panel in the drywall to access the supply pipe and the regulator would be better protected from the elements inside rather than in the ground. Also I was considering using the push on Sharkbite fittings instead of solder. Any help or suggestions are greatly appreciated.
