DIY HVAC Equip. Where?
Discussion in 'HVAC Heating & Cooling' started by Lakee911, Nov 18, 2009.
  1. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Can someone recommend a good place online to buy a new HVAC equip. for the DIYer?
    Thanks,
    Jason
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Google will be your source. Many local distributors will NOT simply because HVAC is not really DIY. For a gas furnace, a permit is mandatory, and a homeowner can do that in some states, but we are messing with gas here.
    For the air conditioning side, a DIY does not have the EPA certificate to purchase and work with R22, and does not have the THOUSANDS of dollars worth of tools....recovery system, vacummp pump, gauge manifold, brazing set, etc. Not to mention the knowledge of how to set your superheat/subcool, etc.
  4. Lakee911
    Aug 23, 2005
    Columbus, OH
    I have no problem working with gas or pulling permits. Doing furnace or maybe unit heater install only, no A/C.
    I'll keep googling...
    Jason
  5. jimbo
    jimbo Plumber
    San Diego, CA
    Well, again....there are websites. Check it out. It will be hard to source locally, I suspect/
  6. burleymike
    burleymike New Member
    Nov 4, 2008
    Idaho
    I just found several store fronts on ****. There are probably others as well on the internet. Some local shops will usually work with you. They can size the equipment and make all the duct work then you can install it.
    You will probably pay more buying local but you will have support you can not get online. If doing A/C they can braze the joints, pull a vacuum, and get it charged properly.
    If you are lucky you might find a local guy with a scratch and dent unit he will sell cheap. Reputable business will not install scratch and dent so somebody that will take them off their hands for some $$$ is a good deal for everybody.
Similar Threads: HVAC Equip
HVAC Heating & Cooling Computer Equipment Room and Fresh Air Circ with HVAC? Jan 14, 2008
HVAC Heating & Cooling Balancing my HVAC system? Dec 12, 2016
HVAC Heating & Cooling Help in Picking Replacement Central HVAC system Nov 24, 2016
HVAC Heating & Cooling I have a couple of HVAC questions Nov 7, 2016
HVAC Heating & Cooling HVAC Ducts in Attic Oct 6, 2016
