diverter valve vibrates
Discussion in 'Shower & Bathtub Forum & Blog' started by mick04u, May 23, 2005.
  1. mick04u
    mick04u New Member
    May 22, 2005
    Hello all....hope you can help me. I have a 3 handle tub/shower faucet. Due to a leaking hot water handle, I replaced the hot water stem assembly. That fixed the problem, but then water was running out the tub spout when the flow was directed to the shower head. I then replaced the diverter stem (I have a compression faucet). After replacing, it solved the problem, but then a new problem surfaced. Now, when I turn the diverter valve to shower or tub, I get a vibration at the beginning that goes away when fully opened either way. I thought this may be the valve seat and attempted to remove. I attempted to remove with a seat wrench and in doing so, I seemed to have stripped the valve seat. I've tried to spray it with WD40, but it doesn't want to budge. At this point, it's too stripped anyway for the seat wrench to catch. I made sure all the washers were intact on the valve stem and reinserted, but still have the vibration. Is the valve seat the cause of the vibration when beginning my turn to divert the water from tub to shower or could it be another problem? It only seems to happen when diverting hot water alone and not cold water alone. Am I over looking something? If it is the valve seat for the diverter valve, how can I remove the valve seat now that it is stipped? If it is not the valve seat, what else can it be? Is my only recourse at this point is replacing the entire manifold assembly?
    Please help!!
  2. hj
    diverter
    The diverter is a double seated stem, so it had washers both on the end and partway up the stem. In addition some have a thin plastic "sealing" washer by the upper seal. If that is loose after the diverter is installed it can vibrate. Hot water could also be expanding something causing it to vibrate. It is not likely to be the seat you stripped causing the noise.
  4. mick04u
    mick04u New Member
    May 22, 2005
    Diverter
    The diverter I have is a Sayco. It does not have a thin plastic sealing washer but does have washers at end and part way up and another under the Bonnet nut. Nothing seems to be loose and all washers and stem are new. Any other thoughts?
Similar Threads: diverter valve
Shower & Bathtub Forum & Blog Upgrade Manufactured Home 2 Handle Valve with Bath Shower spout and diverter Jan 11, 2017
Shower & Bathtub Forum & Blog Unknown shower diverter valve, need help with ID.. Apr 17, 2016
Shower & Bathtub Forum & Blog Delta Diverter Valve Bonnet Nut Removal Apr 7, 2016
Shower & Bathtub Forum & Blog How does shower line drain through tub spout when valve is off and diverter is set to tub? Apr 3, 2016
Shower & Bathtub Forum & Blog How to get this diverter valve out Nov 18, 2015
