Diverter Valve Issues?
Discussion in 'Shower & Bathtub Forum & Blog' started by SeattleSoxFan, Apr 1, 2005.
  1. SeattleSoxFan
    SeattleSoxFan In the Trades
    Apr 1, 2005
    Carpenter
    I have two "odd" behaviors in a newly plumbed three-valve tub/shower (Price Pfister).
    1. A fairly strong flow of water coming out of the tub while the shower is in use. (This made me initially suspect the diverter valve.)
    2. When the water is turned off, it continues to drain out of the tub for almost a minute of a _slowly_ tapering to nothing flow. This happens with both hot and cold, and is accompanied by a lovely "gulp-gulp" sound. It does stop eventually, which makes me believe that the hot/cold valves are properly working.
    Through reasons too long to explain here, I actually have another whole shower set (same model even), so I swapped out the diverter valve and found a suspect "bonnet washer" but the replaced unit had no such defect. However, the exact same behavior still occurs...
    What next?
Similar Threads: Diverter Valve
Shower & Bathtub Forum & Blog Symmons / Temptrol valve, Water comes out of tub spigot when shower is on - New diverter did not fix Feb 27, 2017
Shower & Bathtub Forum & Blog Upgrade Manufactured Home 2 Handle Valve with Bath Shower spout and diverter Jan 11, 2017
Shower & Bathtub Forum & Blog Unknown shower diverter valve, need help with ID.. Apr 17, 2016
Shower & Bathtub Forum & Blog Delta Diverter Valve Bonnet Nut Removal Apr 7, 2016
Shower & Bathtub Forum & Blog How does shower line drain through tub spout when valve is off and diverter is set to tub? Apr 3, 2016
