Diverter turns round and round and....
Discussion in 'Shower & Bathtub Forum & Blog' started by rob21275, Jan 30, 2008.
  1. rob21275
    rob21275 New Member
    Jan 30, 2008
    I just finished a remodeling of my front bathroom. After making sure I had no leaks, I added my escutcheons and was installing the knobs.
    I run my final test -- everything looks good.
    Then I go to turn the diverter to the shower position ... and the knob keeps turning and turning and turning .... going between faucet and shower, but never "stopping".
    FWIW, the diverter stem is a Harcraft with the white plastic end. (See the following address for a picture: http://www.plumbingparts.org/parts/982843.html)
    I have the same diverter in the other bathroom, and it stops after a couple of turns in one direction for the shower, and vice versa for the faucet.
    I am concerned that if I use the "infinitely turning" diverter/shower, it could develop a leak. As replacing them seems ridiculous (the remodel was a long project, so the stems were installed months ago but haven't been used other than to test them a couple of times), is there something I might need to tighten, or is this thing broken already?
    Finding these things wasn't even easy; Lowes' had the hot/cold stems, but I had to drive 20 miles to a specialty plumbing shop for the diverter, and they weren't cheap. I'd like to avoid that again, if possible.
    Any help would be greatly appreciated! Thanks in advance.
  2. hj
    diverter
    I am not familiar with that specific brand of diverter, but that type typiclcally just rotates 180 degrees with an internal stop to limit it to rotating half way. Yours must have a broken stop from the description of the problem.
  4. rob21275
    rob21275 New Member
    Jan 30, 2008
    Yeah...I looked at it, and the little "stopper" tab is not catching the outside of the groove cut for it to move in, causing it to go the full 360 degrees instead of stoping at 180.
    I'm not really sure if it's just made wrong or if it the pipe which the stem is in.
    But thanks for your help.
Similar Threads: Diverter turns
Shower & Bathtub Forum & Blog Shower Diverter Help Today at 11:00 AM
Shower & Bathtub Forum & Blog Pegasus Diverter stuck - how to get into it? Mar 12, 2017
Shower & Bathtub Forum & Blog Symmons / Temptrol valve, Water comes out of tub spigot when shower is on - New diverter did not fix Feb 27, 2017
Shower & Bathtub Forum & Blog help finding shower head diverter Jan 28, 2017
Shower & Bathtub Forum & Blog Upgrade Manufactured Home 2 Handle Valve with Bath Shower spout and diverter Jan 11, 2017
