Diverter spout leaks when water is off
Discussion in 'Shower & Bathtub Forum & Blog' started by dakota, Aug 14, 2011.
  1. dakota
    dakota New Member
    Aug 14, 2011
    Toronto, ON
  2. jadnashua
    Your valve is leaking...now, it is possible to get a few drips after use for awhile, but that should stop fairly quickly.
  4. dakota
    dakota New Member
    Aug 14, 2011
    Toronto, ON
    Yes I figure that, but it seems weird that it's not a continuous leak. Do I need to get a new cartridge for a new faucet that I have yet to use? I would like to know if this is a common problem with these fixtures? This really irritates me.
  5. jadnashua
    Leaks can be caused by failing to flush the lines before inserting the cartridge (which can trap stuff under the seals and scratch things), overheating things if you soldered it, a bad cartridge, or scores or scratches in the valve body. It's also possible to get a porous casting, but not too common. Call Moen and talk to their tech support - they'll advise and send you the part(s) you'd need to resolve the problem.
  6. dakota
    dakota New Member
    Aug 14, 2011
    Toronto, ON
    Thanks!!
    There was no soldering as the faucet only takes threaded fitting. I'll contact Moen and see what they say.
  7. SteveMar
    SteveMar New Member
    Aug 22, 2009
    Maryland
    I have a related post that I put up recently regarding this Posi-Temp cartridge (MOEN 1222B). I had a bathroom remodel in March 2011, and I am about to install the 4th Posi-Temp cartridge since then, all because the tub spout leaks after the water is off. While what Jim says above is true (and he replied to my posted thread as well), I am starting to believe that the 1222 is not that great. It is true that Moen will send you a new cartridge (they've done this for me a few times), but this past go around they told me they had a redesigned cartridge. This does not appear to be true--the one they sent is a 1222, and it came without any identifying part number, and no plumber's grease. You will want to get some silicone based plumbers grease before you install the cartridge. And good luck--I know how frustrating this is--my first cartridge was leaking even before the bathroom remodel was done.
  8. hj
    A cartridge leak will NOT stop by itself. You do NOT need to "use the shower" for some water to get into its riser pipe, it will just NOT be enough to dribble out of the shower head.
  9. jadnashua
    Well, to be more correct...the spout isn't leaking - it is essentially an open pipe; the valve is leaking and it just happens to be coming out of the spout. Now, why the valve is leaking is the big issue. It could be the valve body has a defect, or the cartridge is bad, or not installed properly.
  10. Terry
    Aug 17, 2004
    After a shower is used, it takes 35-40 minutes to finally stop dripping.
    If the shower has "never" been turned on, then there should be no dripping. But once you use the shower again, the clock restarts.
  11. dakota
    dakota New Member
    Aug 14, 2011
    Toronto, ON
    I did contact Moen, they sent me a new cartridge. I replaced the factory installed cartridge with the new replacement. No more leaks, the original one was defective.
Similar Threads: Diverter spout
Shower & Bathtub Forum & Blog Upgrade Manufactured Home 2 Handle Valve with Bath Shower spout and diverter Jan 11, 2017
Shower & Bathtub Forum & Blog Is this Grohe leaky tub spout diverter repairable?? Jan 2, 2017
Shower & Bathtub Forum & Blog Slip-on tub spout w/ diverter recommendation? Sep 20, 2016
Shower & Bathtub Forum & Blog Water comes out from shower diverter spout May 23, 2016
Shower & Bathtub Forum & Blog How does shower line drain through tub spout when valve is off and diverter is set to tub? Apr 3, 2016
