Distance from main panel to subpanel (plus)
Discussion in 'Electrical Forum discussion & Blog' started by mchiarit, Nov 26, 2007.
  1. mchiarit
    mchiarit New Member
    Jul 19, 2005
    Virginia
    Is there a minimum distance between a main panel and a subpanel? If so, what is it? Also, is it acceptable to feed a subpanel from another subpanel?
    I have a main panel with a 200 A breaker (no other circuits) that feeds what used to be a main panel (it was converted to a subpanel when I added the 200 A main) and I would like to add a subpanel fed from a 60 A breaker in my existing subpanel.
    That's the short story. The rest of the story is that I want to add a feed from an emergency generator. The 60 A breaker will have 4 G wire going to a transfer switch and 4 G wire going to the new subpanel. There will also be 10 G wire going to the transfer switch being feed from an emergency generator that is protected with 240 V 30 A breaker. The new subpanel with have the following circuits:
    240 V 30 A
    120 V 20 A (two)
    120 V 15 A (two)
    It is also intended that the 30 A breaker will be off while the emergency generator is on, or on with all other breakers off.
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    NO, and YES.
  4. mchiarit
    mchiarit New Member
    Jul 19, 2005
    Virginia
    Thanks Speedy, you answered the two most important of the questions I had.
Similar Threads: Distance main
Electrical Forum discussion & Blog Cat5/Coax run short distance along side electric conduit Jul 18, 2016
Electrical Forum discussion & Blog Distance From Meter to Disconnect Jun 26, 2014
Electrical Forum discussion & Blog Receptacle distance from cooking range? Apr 22, 2014
Electrical Forum discussion & Blog Distance of GFCI Breaker Apr 26, 2012
Electrical Forum discussion & Blog Baseboard electric heater & switch distance from whirlpool bathtub? Jan 25, 2012
