Disposal too heavy to hold up and screw in at the same time.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cellardoor, Jun 7, 2011.
  1. cellardoor
    cellardoor New Member
    Jun 7, 2011
    Ann Arbor, MI
    Had to remove garbage disposal--now can't replace it. Has anyone any ideas of how to prop the disposal up and turn the top--all by myself. Getting a strong man to do it is not an option--if I can help it.
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    I used my knee to hold it up, and a strong man will have a hard time.
  4. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    If it is ISE then the strainer would hold it up.
  5. plumber2011
    plumber2011 Expert Plumber
    Jun 4, 2011
    Licensed master plumber and owner of small residen
    Boston, Massachusetts
    Hi Cellardoor
    I would just recommend that you temporarily block the disposer up using telephone books and other sturdy books you find around your house until you can set the disposer in place and tighten the collar. That should be all you need here...;)
  6. hj
    I use my knee, but when the sink drain is back too far it can be a challenge. Use your car jack to lift it. BUT, if you are reinstalling the same disposer, corrosion and age, can make it very difficult to engage the locking ring even with the disposer supported.
Similar Threads: Disposal heavy
Plumbing Forum, Professional & DIY Advice High Wall Drain, New Sink & Disposal Dilemma Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Perfect Grind Garbage disposal problem Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Help with garbage disposal replacement Dec 26, 2016
Plumbing Forum, Professional & DIY Advice UK running trap for garbage disposal Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Dishwasher drain not close to sink or disposal, is this okay? (Images) Nov 28, 2016
