disposal backup in to other sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sspeed, Jan 16, 2012.
  1. sspeed
    sspeed New Member
    Jan 16, 2012
    Colorado
    When we bought this house nearly everything was wrong, down to the duct tape on electrical connections. While I've sorted most of it out, the disposal continues to elude me. When we turn it on it literally shoots water up in to the other sink.
    From a layperson's point of view it all looks right, it has a baffled T which appears to be in the right spot, the disposal drain tube is higher than the trap, the disposal tube is level (despite how my awesome camera angle looks)... what is going wrong? Here are 3 pics...
    [​IMG]
    [​IMG]
    [​IMG]
  2. Terry
    Aug 17, 2004
    I would pull the p-trap and make sure the drain below isn't plugged.
    If the drain is clear, then you shouldn't have water coming up the other drain.
  4. Pipewrench
    Pipewrench In the Trades
    Mar 28, 2011
    Service plumber
    Jackson MS
    Does it do it when the disposal is completely clear with water flowing properly? If it has food in it and the bay is filling up then it tends to do it when you cut it on to clear it.
  5. sspeed
    sspeed New Member
    Jan 16, 2012
    Colorado
    It's usually when the disposal is not clear. I usually modulate the switch to get it moving and stop it from shooting out the other sink.
  6. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    It is shooting out the other sink ?
    I find that very hard to believe.
    Please post videos. That must be cool.
  7. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    You have a partial stoppage and the waste pipe need to be augered.
    Snaked or rodded out.
  8. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Call a plumber or drain cleaning service co. To clear your kitchen sink drain into the main line and the water will stop coming back up into the sink !
  9. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    True that.
    I still would like to see video of it "shooting out the other sink."
  10. jimbo
    jimbo Plumber
    We can see in the photo that your Tee appears to be the "baffle" type, so only some clogging should cause that back up.
  11. Pipewrench
    Mar 28, 2011
    Service plumber
    Jackson MS
    Sounds like you are just moving a lot of water at one time with a good disposal. Looks like a badger 5. It wouldn't hurt any to install a new basket strainer too. You are missing the cross that is usually there. Doesn't sound like a blockage in the slab to me.
  12. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    If it is "shooting out the other sink." just put a plug in the other sink and clear the obstruction, by using plenty of HOT water.
  13. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Is there any such thing as a good disposal.?
    They should not be allowed unless you have your own septic system, and have to deal with the problems that they cause to a sewer system. You would never own one, if you seen what is going down the drain.
    They are right up there with Tampons, On most reasons are taxes have to pay for Sewer Blockage. Trash in so Called "Storm Drain" comes next.
    Just me. I do apologize in advance. Go ahead and chew my ass out.
    DonL
  14. sspeed
    sspeed New Member
    Jan 16, 2012
    Colorado
    Sorry for the Vimeo, my phone was having trouble posting to YouTube... this will take about an hour to be available..
    [video=vimeo;35174932]http://vimeo.com/35174932[/video]
    This is the mild case that it does it, sometimes it's high enough to hit you in the face, usually when water is sitting in the sink... The line from the sink has been completely replaced and snaked several times before it was replaced...
  15. Pipewrench
    Mar 28, 2011
    Service plumber
    Jackson MS
    Of course there is such a thing as a good disposal. Like I said, a badger 5. It's like I tell customers, they are intended for washing off a plate. Not cleaning out the fridge. It kinda comes down to "common sense". It's gotta travel through a 1 1/2 pipe to hit the 2 inch....
  16. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Yea, They also say that you can put bones in them.
    I am not sold.
    Most people do not care where it goes, Just as long as it gets Disapperated (Yes New Word). It must be FM.
  17. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Guess that was nice, all 7 seconds. I must have missed it.
    Thank you for the try, You must have a Iphone. lol
  18. sspeed
    sspeed New Member
    Jan 16, 2012
    Colorado
    Ha ha, you can see it pop up twice... not nearly as bad as it does sometimes, but just an example...
  19. sspeed
    sspeed New Member
    Jan 16, 2012
    Colorado
    Here's another one, showing what we are used to seeing...
    [video=vimeo;35318005]http://vimeo.com/35318005[/video]
    So, given this is just a Badger 5 moving a lot of water and the P-trap is open and drains nicely, what can we do to keep from getting splashed in the face each time?
  20. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Put a stopper in it ?
  21. sspeed
    sspeed New Member
    Jan 16, 2012
    Colorado
    Yeah, that's the obvious solution as long as the drain is engineered correctly...
Similar Threads: disposal backup
Plumbing Forum, Professional & DIY Advice garbage disposal causing minor backup in double sink Mar 29, 2005
Plumbing Forum, Professional & DIY Advice High Wall Drain, New Sink & Disposal Dilemma Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Perfect Grind Garbage disposal problem Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Help with garbage disposal replacement Dec 26, 2016
Plumbing Forum, Professional & DIY Advice UK running trap for garbage disposal Dec 22, 2016
