Dishwasher not draining
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by kpd007, Sep 7, 2005.
  1. kpd007
    kpd007 New Member
    Sep 7, 2005
    Neat forum. So, for my first post I will ask for help. Two years ago I installed a Kenmore dishwasher and it has worked great since day one. It was not a hard install as I only replaced an existing aged dishwasher. Now after two years, the dishwasher will not drain completely. There is usually about two inches of standing water in the bottom. The drain air gap has not overflowed. When I use the "drain" cycle it still will not drain completely?? Any help would be greatly appreciated.
    Thanks
    KPD007
  2. jimbo
    jimbo Plumber
    One thing to check is the entire drain hose, all the way from the DW. Any kink, or internal clog, can cause problems. Otherwise, it may be the pump.
    There is an excellent appliance repair forum at http://homerepairforum.com
  4. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    maybe
    a chunk of meat in the hose?
  5. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    If it is worth your time I would take the bottom pull out grate, inspect the screen inlet in the center of dishwasher. If there are screws (most likely) then unscrew them and remove the inlet screen. Even though those holes are small, sometimes weird stuff gets past the screen. Shrimp tails, toothpicks, rabbit grass from easter are just a sample of some things that I have seen make it through the hose and clog an air gap. :confused:
Similar Threads: Dishwasher draining
Plumbing Forum, Professional & DIY Advice Dishwasher draining problem! Nov 5, 2016
Plumbing Forum, Professional & DIY Advice Problem with draining dishwasher Feb 28, 2016
Plumbing Forum, Professional & DIY Advice 13 year old GE dishwasher not draining Nov 29, 2014
Plumbing Forum, Professional & DIY Advice Kitchen Sink and Dishwasher Visibly Draining into the Basement Drainage System Sep 4, 2013
Plumbing Forum, Professional & DIY Advice Dishwasher motor sparks; not draining properly Apr 20, 2013
