dishwasher install
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by i_ride, Jun 28, 2006.
  1. i_ride
    i_ride New Member
    Jun 28, 2006
    Hello....Im rebuilding my kitchen (new everything) It is going to be L shaped....with the sink on the short side of the L....then a 42"corner cabinet, stove, and dishwasher on the other side of the L. Therefore the dishwasher is going to be pretty far from the sink. What is the best way to hook up the supply/drain lines for the dishwasher (the current supply lines and drain for the sink will remain where they were) ? should I still drill through the cabinets and hook up under the sink ? or can I run a new water line and drain underneath up to the dishwasher ?( i have access underneath in the basement )
    thanks for the help.
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Yes, run all the lines through the basement, drain and supply. If you ever had a leak and they were under all that you would have quite the mess.
  4. norcal1
    norcal1 Plumber/Owner
    Jan 24, 2005
    Yes, I would also go thru the basement ceiling.
    You never know if you or a future owner are going to remodel the basement and put up a ceiling, so I would do the work as if it were going to be covered up in the future.
    Do it once, do it right, be done with it. ;)
Similar Threads: dishwasher install
Plumbing Forum, Professional & DIY Advice Installing a Samsung Dishwasher with existing Johnson Tee Nov 22, 2016
Plumbing Forum, Professional & DIY Advice Permanently Install Countertop Dishwasher Jun 1, 2016
Plumbing Forum, Professional & DIY Advice Dishwasher Installation Problems May 18, 2016
Plumbing Forum, Professional & DIY Advice Appliance company thinks my dishwasher install is complicated... Apr 18, 2016
Plumbing Forum, Professional & DIY Advice Can I install a compact front load washer in the place of the dishwasher? Apr 3, 2015
