Dishwasher filling with sink water
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by my3angels, Jul 26, 2011.
  1. my3angels
    my3angels New Member
    Jul 26, 2011
    Redding, CA
    I read a previous post about sink water backing up into the dishwasher, and the suggestion of a 'gap' being installed, but my sink and dishwasher have a little different issue than that post.
    My sink & dishwasher drain well, but I noticed a sour smell emerging from the dishwasher yesterday, and found 'dirty' water about two hours after emptying it. It appears the sink is draining into the dishwasher, leaving 'dirty' water to pool into the bottom of the dishwasher, even though the sink drain appears to be clear. Any ideas why this would suddenly start? I bought the house (lemon) four years ago, and this is the first problem like this.
  2. Terry
    Aug 17, 2004
    And that's why you would install an air gap. It prevents water that has been in the disposer or sink from going back to the dishwasher.
    [​IMG]
  4. hj
    You must have a sink drain problem because that is about the only way that water could drain, or be siphoned back into the dishwasher. If so, an air gap would solve the symptom, but not the problem.
  5. my3angels
    Jul 26, 2011
    Redding, CA
    In the meantime, can I drain the dishwasher and plug the drain at the pipe? Will this prevent the sink water from draining into the dishwasher until I can hire a plumber? I can handwash dishes until then, but I don't want to cause more bacteria to build up in the dishwasher until it's fixed. Can you also give me an average price for an air gap so I have an idea what my expenses will be?
  6. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Like HJ said, installing an air gap won't fix the problem which is a plugged sink drain. You can clamp vice grips on the dishwasher hose until you get the drain fixed. Oh and dump some clorox in the bottom of the dishwasher and run a cycle to clean it out.
  7. my3angels
    Jul 26, 2011
    Redding, CA
    Thank you for all the help. I got a snake, and cleaned the pipes, but I will block the hose until I can get an air gap installed. Thanks for the reminder about the bleach for sanitizing also.
  8. hj
    IF the drain is open and you do NOT use the dishwasher, there is no need to "block" the hose.
  9. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    Impossible to know what causes an intermittent problem (in any system, not just plumbing) until you expend a lot of time diagnosing possibilities.
    So far, I haven't read any mention of the positioning of your dishwasher drain hose. Did you write that out somewhere already? The next best thing to an air gap is a hose that is positioned in a HIGH loop upwards to the underside of the countertop and back down to the connection point with the drain pipes. That configuration geometry is known as a "high loop". The hose goes up, up, and up. Then it goes down down down.
    What is the positioning of your dishwasher drain hose?
    The advantage of an air gap is that it TELLS you there is a problem. You were lucky to have spotted it by yourself.
    What to do next? Diagnose, diagnose, and diagnose.
  10. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    All the sink tailpiece adapters for dishwashers I have seen are a Wye type shape, so unless there was a partial clog in the drain below the adapter, I don't see how running the kitchen sink would allow water to flow up the wye. then again, maybe your tailpiece adapter is not a wye, and you don't have the high looped dishwasher hose configuration either. I believe there is a partial clog below the adapter. Is there a garbage disposer in this setup too?
Similar Threads: Dishwasher filling
Plumbing Forum, Professional & DIY Advice Muddy Water Filling Up Sink and Dishwasher-SOS!!! Feb 16, 2014
Plumbing Forum, Professional & DIY Advice Dual kitchen sinks not draining. Filling up both sinks and dishwasher. Feb 4, 2012
Plumbing Forum, Professional & DIY Advice Moving kitchen sink and dishwasher, vent question Sunday at 6:24 AM
Plumbing Forum, Professional & DIY Advice Help sizing kitchen sink/washer/dishwasher water supply Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Both Sinks and Dishwasher Backing Up Jan 13, 2017
