dishwasher drains water but not suds- please help
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by stanleyoutdoors, Nov 21, 2011.
  1. stanleyoutdoors
    stanleyoutdoors New Member
    Nov 21, 2011
    colorado
    My adora quietpower3 dishwasher is not getting the the soap out.
    I blew compressed air thru the drain line and it is open. Likewise the drain it goes into. I hooked 110 VAC power up to the drain pump motor and it turned fine. I also cleaned the drain screen inside. I put the drain line into a bucket and it pumped out about 1 gallon of water. But at the end of a wash cycle it still has about 6 inches of suds at the bottom of the washer and the dishes are still sudsy. It's about 2 yeas old. I never had to use a rinse agent before.
    Thanks for any help
  2. jimbo
    jimbo Plumber
    There should be no discernible suds in a dishwasher. Are you sure the wrong soap didn't get in there? A dishwasher pump will not pump out suds.
  4. mtcummins
    mtcummins In the Trades
    Jun 25, 2010
    General Contractor/Property Manager
    Pittsburgh PA
    you're not using dish soap are you? that will give that effect, if it doesn't basically explode the door and run out all over the floor... you can only use dishwasher detergent in a dishwasher. made a few service calls b/c of this mistake.
  5. jacobsond
    jacobsond DIY Junior Member
    Apr 30, 2010
    Fairmount, North Dakota
    Dishwasher soap does not foam. You have the wrong soap in there. Run a load without dishes or soap and put come cooking oil in there to kill the foam or get some defoamer they use for hot tubs to kill that foam.
  6. stanleyoutdoors
    Nov 21, 2011
    colorado
    I'm using the same dishwasher soap that never foamed in the past. It just started doing this recently
  7. hj
    You did not accidently put soap in the "JetDri" dispenser did you? ANY suds should be broken up and flushed out during the rinse cycle, unless something is creating more suds during that cycle, OR no water is entering the dishwasher during that cycle.
Similar Threads: dishwasher drains
Plumbing Forum, Professional & DIY Advice Kitchen sink gurgles loudly when dishwasher drains Dec 20, 2016
Plumbing Forum, Professional & DIY Advice Floor drains below laundry, dishwasher, fridge? Jan 5, 2015
Plumbing Forum, Professional & DIY Advice Stinky dishwasher and washing machine drains Sep 24, 2012
Plumbing Forum, Professional & DIY Advice Dishwasher & garbage disposal - for septic field drains Feb 12, 2011
Plumbing Forum, Professional & DIY Advice Dishwasher and furnace drains Mar 10, 2008
