Dishwasher Drain to Disposal Req'd?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by whizmo, Aug 10, 2005.
  1. whizmo
    whizmo New Member
    Aug 10, 2005
    Hi, while doing a minor kitchen remodel with new sinks and faucets, I discovered the our ten-year-old house was originally plumbed with the waste line from the dishwasher draining directly to the sink waste line (through an air gap) rather than going through a garbage disposal that sits right next to the dishwasher. (The disposal's dishwasher inlet knockout plugs are are still intact, so it's been this way since the house was built.)
    Is this Okay? It's been fine for ten years and I know that if there is no disposal, then this is acceptable, but I'm seeing some reports that a connection to a disposal, if one exists, is required by code and highly recommended.
    I'm in the Seattle area, BTW.
    Thanks
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Boy, I sure hope it's OK. I don't have a garbage disposal in my house and the DW goes into a tailpiece above the sink trap. Don't have a airgap either, just looped the hose under the countertop.
  4. Terry
    Aug 17, 2004
    The dishwasher doesn't need to drain to the disposer.
  5. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    ok but better to
    Its ok, and either way works....
    more a matter of convienance to have
    an easy place to install that dw into
    Though I have always felt that through
    the garbage disposal any large residue
    that might be on the dishes would get a
    little better groundup ....before going down the drain...
    whatever
  6. jimbo
    jimbo Plumber
    Here we almost always see it connected to the disposal, although I don't believe code requires that. The drawback is, if a person tends to leave a lot of food scraps on the plates as they go to the DW, enough stuff in the waste water can clog the grind chamber in the disposer. I had to "train" the misses to try to remember to cycle the disposer briefly after the first wash cycle in the DW.
  7. whizmo
    whizmo New Member
    Aug 10, 2005
    Thanks everyone. If I every rework the plumbing, I'll put it throught he disposal, but for now, I'll let it go and just be sure to scrape dishes well. Appreciate the advice.
Similar Threads: Dishwasher Drain
Plumbing Forum, Professional & DIY Advice Kitchen sink gurgles loudly when dishwasher drains Dec 20, 2016
Plumbing Forum, Professional & DIY Advice Dishwasher drain not close to sink or disposal, is this okay? (Images) Nov 28, 2016
Plumbing Forum, Professional & DIY Advice Dishwasher draining problem! Nov 5, 2016
Plumbing Forum, Professional & DIY Advice Dishwasher drain advice Aug 22, 2016
Plumbing Forum, Professional & DIY Advice Dishwasher drain hose Jun 22, 2016
