Richrc1131
I recently had to replace my garbage disposer and dishwasher. I reconnected the wiring as it had been on the old machines, but the circuit now trips.
Here is the setup:
power --> dishwasher --> garbage disposer --> switch
To the best of my knowledge, I hooked everything up the same as it had been, I noticed in the directions of the disposer that the green grounding wire needed to be attached to the grounding screw on the unit. I mistakenly connected the ground wire from the incoming power line.
Would this be the cause of the circuit tripping?
Here is the setup:
