Dishwasher/disposal wiring
Discussion in 'Electrical Forum discussion & Blog' started by JMingrone, Nov 26, 2012.
  1. JMingrone
    JMingrone New Member
    Aug 21, 2006
    Do a disposal and DW HAVE to be on separate circuits? I have 2 circuits allocated for them, but one has plenty of capacity to run both. Can I simplify and run both off the one?
    Also, Can the NM cable just come thru a hole in the sheetrock into the area where the sinkbase will be and after the sinkbase is installed, put a JB inside?
    Thanks
    -Jay
  2. jadnashua
    Depends...if the installation instructions call for separate circuits, you should use separate circuits. Disposers are available in at least up to 1Hp versions, which along with a DW that was heating the water, might overload the circuit. So, to preserve long-term potential changes and options, an extra circuit won't hurt.
  4. hj
    In some cases, if not MANY, since the disposer, (NOT "Disposal"), switch is combined with other switchs or outlets above the countertop level, it is wired into that circuit and the dishwasher is separate, even though the disposer and dishwasher share the same duplex outlet.
  5. JMingrone
    Aug 21, 2006
    Went ahead and ran both wires. Easy enough to do.
    Thanks guys,
    Jay
  6. big2bird
    big2bird IBEW Electrician
    Sep 29, 2012
    IBEW Electrician
    Anaheim, Ca.
    I would run a 14/3 cable, feed it from a 2 pole 15 ampere breaker, and cut the tab between the upper/lower receptacle on the hot side.
Similar Threads: Dishwasher/disposal wiring
Electrical Forum discussion & Blog Switch Wiring - 3 way? Sunday at 2:40 PM
Electrical Forum discussion & Blog Mini Split wiring Question Apr 16, 2017
Electrical Forum discussion & Blog Wiring a 3 wire 220v dryer receptacle with a 4 wire setup Apr 14, 2017
Electrical Forum discussion & Blog 3-Way Switch Wiring Help... Apr 8, 2017
Electrical Forum discussion & Blog Dishwasher wiring all of a sudden overheats and melts Feb 27, 2017
