So we are replacing our dishwasher from an old GE profile to a Bosch tall tub (to be delivered this week).
The GE is currently connected to the hot water line in the basement and fed through the floor using soft copper. due to the design of the Bosch and it's base I am going to have to move the place the water line hole is and will need a longer line. So I am thinking I will not be able to use the current soft copper.
The distance from the hot water shutoff valve to the dishwasher inlet is going to be roughly 10 feet, so I am considering using 2 braided s/s hoses with a connecter in between (so i get a 10 ft hose that I can't seem to find) to hook it up to the water to the dish washer.
my questions are:
Is this a viable solution? and how reliable will it be?
Does it matter if I use two 5 ft hoses or a 6 ft and a 4 ft?
I did consider using pex, but figured this will be easier to install since i just have to screw the connections on to the shutoff valve and didn't need any special tools to crimp the pex or wasn't sure about the reliability of sharkbite connectors.
I am not considering using copper because of the design of the bosch dishwasher and think it'd be a pain if i ever have to take the dishwasher out for any sort of serviceand any sort of need to unbend the copper line so that I could take the dishwasher out.(this is due to the design of the bosch that has a plastic base.)
I am also considering using the drain hose so i dont have to re run it , that is if the connector to the drain hose is the correct size. is this an ok idea or should I consider replacing it with a new one. (I am hoping the drain connector size will be the same) I want to install a new hose because again the current dishwasher is run through the joists in the basement and then back up again to the kitchen drain on the main floor.
anyways, any advice or comments would be appreciated.
thanks in advance
my questions are:
thanks in advance
