Discovered a 10 AWG Cable
Discussion in 'Electrical Forum discussion & Blog' started by GoldMaple, Oct 7, 2009.
  1. GoldMaple
    GoldMaple DIY Junior Member
    Jul 11, 2009
    Edmonton, Alberta
    I live in an old house and I have been doing some renovating. I was looking for a way to get to my electrical panel because I'd like to run a couple of new circuits into my basement. Given the location of the Panel it was not going to be an easy task. While looking for a route I discovered a wire coiled up and stuck in the joists. It was brand new and disappeared so I opened up the panel upstairs and there was the other end coiled up in the Panel box. It was not hooked up. :) How handy! So, the wire is fairly thick and it has "10 AWG 300 volt" stamped on it. So, I think it's 10 gauge and capable of handling 30 amps? My question is.... Can I attach a very small panel box in my basement to this wire and add one 10 amp and two 15 amp breakers? Or am I constrained to the 30 amps, so only two 15 amp breakers? I'm not sure what this cable is capable of handling. Thanks!
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    30A does NOT mean "two 15a breakers". Also, there are no 10a breakers. If you find one it is an oddball and most likely for industrial use.
    Let's get the basic info first. What conductors are in this cable? If it is black, white, red and GROUND (bare or green), then you can effectively install a sub-panel.
    If it is just black, white and ground then you can install a sub-panel, but it would be a bit hacky as you would be limited to a 120v panel.
  4. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    You can provide any number of breakers provided that you don't exceed the 30A of the cable (which is protected by the panel's main breaker). You'll need to do load calcs to ensure that your loads are within 80% of 30A.
    You'll have a tough time finding a panel with a 30A main. Most likely you'll need to backfeed the panel through a breaker which has some requirements (labeling and hold down, I believe).
  5. GoldMaple
    Jul 11, 2009
    Edmonton, Alberta
    Wires
    Okay, good. The cable has 4 wires, a red, black, white and a bare wire. I'm hoping that I could add a small panel with 4 breakers. I mentioned a 10 amp breaker because I would like to run a dedicated circuit into the bathroom I'm renovating and use it for the heated floor. All the manufacturers stated that it must be on a dedicated circuit or the GFI will be tripping all the time. The heated floor will take less than 4 amps because the bathroom is so small. Another breaker I'd like to run to my washing machine because someone connected the current circuit to the kitchen upstairs so when my microwave goes on and the washer is on the breaker trips. The third breaker I'd like to save for when I redo my upstairs bathroom and use for the heated floor. Again, it will draw less than 4 amps when running. Both heated floors won't be running all the time. Probably run then on a programmable timer for times we know we'll use it. I would then like to have the option of adding one more circuit for future use. Does this seem reasonable?
  6. hj
    wires
    I would use a small sub panel without the main since the 30 amp breaker in the main panel would provide the "master" breaker function.
  7. Ian Gills
    Jul 24, 2007
    USA
    It can't be done with what you are intending to do, but if my needs were more modest (two 15 or 20 amp circuits) I would be tempted to use that cable as a shared neutral and run two circuits directly from the panel using it.
    Of course you cannot very easilly use GFCI or AFCI breakers with a shared neutral and these are very often required with certain types of new wiring work.
  8. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Sounds reasonable to me.
  9. Speedy Petey
    Jun 16, 2007
    NY State, USA
    He does NOT need a 30A main.
    He can use any panel. Typically a small sub-panel will have a 60 or 100A rating. They can be fed with anything from 30A up to their rating.
    Also, no main breaker is required since this sub-panel will be within the same structure as the main panel. A main-lug panel would be a typical install.
  10. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Why can't it be done?? Sounds like it will to me.
    Also, two-pole GFCI breakers are very common, and two-pole AFCI breakers are getting more common.
  11. Lakee911
    Aug 23, 2005
    Columbus, OH
    You're right. :)
  12. GoldMaple
    Jul 11, 2009
    Edmonton, Alberta
    Another Question
    Thanks for all the replies. I really appreciate it.....:)
    Here's another question. It seems to me that the simplest way to do this is to add a lug sub panel that uses the breakers in the main panel. I understand that I could power the sub panel with a 3 wire cable but it's better with a 4 wire cable and with the 4 wire cable I would use a double pole breaker. What I don't understand is why is it better to use a 4 wire cable in this configuration? Whether I use a 3 or 4 wire cable it's 30 amps so there must be something else?
    (I have a 4 wire cable and will use a double pole breaker)
  13. Speedy Petey
    Jun 16, 2007
    NY State, USA
    A 3-wire cable would give you 30A @ 120v, or 3600 watts.
    A 4-wire cable would give you 30A @ 120/240v, or 7200 watts.
  14. GoldMaple
    Jul 11, 2009
    Edmonton, Alberta
    Okay, so given...
    and "Watts = Volts x Amps" and
    3600 = 120 * 30 3 wire
    7200 = 240 * 30 4 wire
    then by using a 4 wire cable we double the volts which doubles the watts. Based on what I see here is that with a four wire cable I draw twice the power before I utilize all the amps. Is this correct? If so, it's a far superior setup.
  15. Speedy Petey
    Jun 16, 2007
    NY State, USA
    A 240v panel is actually a typical setup. A 120v panel is extremely odd.
  16. Ian Gills
    Jul 24, 2007
    USA
    I did not realise you were so rich Petey. I wish I could afford one of those.
  17. alternety
    alternety Like an engineer
    Apr 2, 2006
    Washington
    This may be an excessively paranoid question, but is the found cable copper?
  18. GoldMaple
    Jul 11, 2009
    Edmonton, Alberta
    Yes, it's copper.
  19. Ian Gills
    Jul 24, 2007
    USA
    I wish it had been gold.
  20. Speedy Petey
    Jun 16, 2007
    NY State, USA
    I don't get this comment. If you are required to use AFCIs what does it matter how much they cost?
    A two-pole AFCI is only slightly more expensive than two single-poles. And if the home run is very long you are saving money on wire.
    If you cannot afford a project or renovation, don't do it. :rolleyes:
  21. Ian Gills
    Jul 24, 2007
    USA
    Crucially, I prefer single pole for 120 volt circuits because I wouldn't want a dual pole breaker tripping two circuits if a fault caused by just one of them was detected.
    If that means spending more money on cable, so be it.
Similar Threads: Discovered Cable
Electrical Forum discussion & Blog Using "MC Lite" (aluminum jacket) cable connectors Oct 13, 2016
Electrical Forum discussion & Blog Switching between AC and MC cable? Oct 13, 2016
Electrical Forum discussion & Blog Underground cable Oct 2, 2016
Electrical Forum discussion & Blog Surface mounted armored cable, or EMT? Sep 21, 2016
Electrical Forum discussion & Blog Limitations on NM cable in tall structures? Aug 18, 2016
