Disconnect for water heater??
Discussion in 'Electrical Forum discussion & Blog' started by hammerslammer, Aug 20, 2007.
  1. hammerslammer
    hammerslammer New Member
    Dec 10, 2005
    Colorado
    I'm moving my water heater and I guess i will need a disconnect at the new location. So i'm thinking a metal box with a double pole single throw 30 amp switch will do. Am I close?? Thanks!!
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    NO! Expensive and more work.
    Use a plain 60A non-fused "pull-out" type disconnect. The type used for A/C installations. They are fully self contained and run about 10 bucks.
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Or
    Use a lock out on the breaket for about $2
  5. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Or
    Maybe he's moving the heater next to the panel so he would not even need a separate disconnect... ;)
  6. hammerslammer
    Dec 10, 2005
    Colorado
    No it will be a good ways from the panel. I was checking out the disconnects that Speedy mentioned at the depot and they look like a pretty good deal . They had a 30 amp and a 60. I guess the 60 is recomended because the breaker will be 30a.?? Thanks for the replys.
  7. jadnashua
    By definition, it would seem that if you have a 30A breaker, the disconnect would need to be rated for at least 30A; I think the 60A isn't needed. If I understand this, it's sort of like sizing the wiring, you can't use less than 12g on a 20A circuit, but 10g would be overkill...why spend the money unless you have a very long run.
  8. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    60 amp disconnect is a pretty common thing you will find in a home center, and cheaper than a 30 amp...
  9. jadnashua
    Sounds like a plan, then. I was just figuring the 30A would be cheaper, and was all that was required. Must be a volume thing...
  10. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Yep... Not really even sure why they make a 30a...
  11. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    I would run 10/3wground from your main panel ,install new 30 amp brkr
    unless you need to upgrade your service and panel.
  12. Speedy Petey
    Jun 16, 2007
    NY State, USA
    I'm not sure what this has to do with the original question about needing a disconnect.
    Also, 10/3 is NOT needed for a water heater. 10/2 is perfect and typical for this installation.
    Using 10/3 is basically wasteful.
  13. hammerslammer
    Dec 10, 2005
    Colorado
    How about the idea that (smart) water heaters of the future might requie a neutral?? Just remembering the days when we ran 10-2 for dryers....
    I did price out a roll of 10-2 and 10-3 the other day. More than a water heater.:(
  14. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Anyone that builds a "smart" water heater that requires a neutral or a 120 Volt circuit has proved that he is not smart enough to build a "smart" water heater.
  15. hammerslammer
    Dec 10, 2005
    Colorado
    Right. I was just wondering if it might be "smart" to run a nuetral...
    22 years ago my plumbers tried to talk me out of lowboy gas heaters in the crawlers. I was too "smart" to listen to them.:rolleyes: I'd like to get this chit right in case i last another 22.
  16. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    10-2 was never allowed for a dryer...need a insulated neutral.... You were allowed to use the neutral as a ground, but not the other way around...
  17. Speedy Petey
    Jun 16, 2007
    NY State, USA
    As I scroll down I see Chris beat me to the reply.
    I see old 10/2 all the times used for dryers. This was NEVER code legal NOR was it ever safe!!!!
    Folks who used 10/2 for dryers simply did not know, or care to know, the code.
  18. hammerslammer
    Dec 10, 2005
    Colorado
    Wow what a shock for me. I guess i've seen it to and assumed that it was allowed in the past. I have some 10-2 to tear out on my oun house but fortunately it was for a future 2nd laundry room and was never used. Thanks,:eek:
  19. hj
    10/2 w grd was the standard for decades before the 4 terminal plugs were adopted. The difference between a dryer and a water heater is that the dryer has a 120 volt control and motor circuit that needs the neutral, whether it is a 10/2 or 10/3 w ground. And they were always "safe" because the neutral and shell were bonded together.
  20. Speedy Petey
    Jun 16, 2007
    NY State, USA
    ABSOLUTELY NOT!
    It was NEVER the "standard". At least by anyone who knew what they were doing.
    As has been said now several times, 10/2 has NO neutral in a 120/240v application. This means the bare ground carried current. This was never allowed and was never safe.
    The ONLY exception was when SEU cable was used. This is the service cable that has two conductors with the grounded (NOT grounding) conductor wrapped around them. This exception is now long gone as well.
    Which is the reason for needing an insulated neutral as opposed to a bare ground. Any kind of 10/3 was safe in the past. 10/2 was NOT.
  21. hj
    In that case there were a "jillion" electricians who did not know what they were doing, including the one that wired my new house 6 years ago, to match my 3 prong male plug. As I said, it was standard for decades. You never saw a 4 prong plug for a dryer until the last decade at the earliest. Maybe you are too new in the business to go back that far.
Similar Threads: Disconnect water
Electrical Forum discussion & Blog Water heater service disconnect question Aug 14, 2010
Electrical Forum discussion & Blog Distance From Meter to Disconnect Jun 26, 2014
Electrical Forum discussion & Blog Heat pump service disconnect Jan 28, 2013
Electrical Forum discussion & Blog Building Service Disconnect question Jan 21, 2012
Electrical Forum discussion & Blog how do i disconnect power on a split buss? Jan 5, 2012
