Discharge from Manganese Greensand filter
Discussion in 'Water Softener Forum, Questions and Answers' started by NC Boy, Nov 3, 2010.
  1. NC Boy
    NC Boy New Member
    Nov 3, 2010
    Dallas NC
    I'm considering installing a managanese greensand filter but would like some information on the discharge of the potassium permanganate solution from the backwash of the filter. What are the environmental effects of the discharge. Do I discharge to septic system, yard, or collect for disposal?
  2. Gary Slusser
    Retired
    Septic system/sewer but, a greensand filter is not a good choice due to having to use expensive and dangerous potassium permanganate. There are other choices just as good or better.
  4. biermech
    biermech Previous member
    Sep 13, 2008
    Owner SWS Systems
    ocala, fl
    I have seen the unit drain in a french drain, into the septic and on the ground. I feel the same as Gary, there are better ways the treat your water other than with potassium permanganate.
  5. NC Boy
    NC Boy New Member
    Nov 3, 2010
    Dallas NC
    So what would be a better system. State lab results at 1.40 mg/l iron, 0.18 mg/l manganese, undetectable magnesium, 12.0 mg/l sulfate, and 17 mg/l calcium. Total Hardness 42 mg/l. Well is 195 feet deep with 10 gallons per minute yield and 33 feet of casing. Sulfate reducing bacteria negative. 5 gal/min flow rate. Problem is the staining of fixtures and cloths.
  6. biermech
    Sep 13, 2008
    Owner SWS Systems
    ocala, fl
    I would recommend a chlorination system followed by a carbon filter. Not only do you sanitize the water, you also oxidize the iron and manganese then the carbon filter will remove them as well as the chlorine from the water.
  7. Gary Slusser
    Retired
    What is the pH?
    What type and size well pump? (single line or two line jet or submersible and how deep if sub)
  8. NC Boy
    NC Boy New Member
    Nov 3, 2010
    Dallas NC
    The pH is 7.1 How is the best way to tell what kind on pump and size? I don't see the pump when I remove the well cover.
  9. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Look for the pump controller, gray box with wires going and coming from it. There should be a label on it that says what size the pump is.
  10. NC Boy
    NC Boy New Member
    Nov 3, 2010
    Dallas NC
    The orginal sample was checked by the State lab. I had the same concerns that you mentioned so a few weeks later, I pulled a sample at 7 am one mourning and checked at a local lab at 9am and pH was the same. I know the lab people who calibrate the meter so I feel the pH is correct.
  11. NC Boy
    NC Boy New Member
    Nov 3, 2010
    Dallas NC
    I don't see a control panel. attached is a picture.
  12. biermech
    Sep 13, 2008
    Owner SWS Systems
    ocala, fl
    The gray box may be where the pressure tank.
  13. Gary Slusser
    Retired
    Only 3 wire submersibles have a control box, 2 wire sub pumps do not have a control box.
Similar Threads: Discharge Manganese
Water Softener Forum, Questions and Answers Head unit and discharge line jammed with mineral deposits. Oct 27, 2016
Water Softener Forum, Questions and Answers Max length for discharge line. Oct 17, 2016
Water Softener Forum, Questions and Answers Lots of resin discharged during regeneration, Fleck 5600sxt Sep 23, 2016
Water Softener Forum, Questions and Answers Presently brine discharge goes in my septic - need to change that! Mar 23, 2016
Water Softener Forum, Questions and Answers Sodium level in softener discharge Jul 22, 2015
