Disabling individual sprinkler heads
Discussion in 'Irrigation / Sprinkler Forum' started by prashster, May 1, 2007.
  1. prashster
    prashster New Member
    Dec 7, 2005
    Is it possible to shut off an individual sprinkler head without digging/removing the head and capping off the tee?
    I'm using Rainbird5000 heads.
    Is there a 'blank' I can screw into the body or is there a special 0GPM nozzle or something????
    Thanks,
    Shawn
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    For any rotor sprinkler head with interchangeable nozzles, you can create a 'blank' nozzle with a bit of silicone caulk inside an old nozzle. The head will still pop up. If that's a problem, you dig it out and cap/plug the pipe connection.
  4. prashster
    Dec 7, 2005
    Great idea. Thanks.
  5. prashster
    Dec 7, 2005
    Followup
    First attempt: Siliconed the nozzle. Forgot to screw it in. Water pressure blew it out.
    Second attempt: Water pressure blew out the silicone.
    Third attempt: Taped the back of the nozzle before inserting it. Worked like a charm.
    Thanks. I didn't want to just cap the line bkz it wld have been a b-ch to find if/when I needed to change.
  6. Wet_Boots
    Mar 23, 2007
    Metro NYC
    When using this method, you're supposed to let the silicone set for awhile. Hunter does make a blank nozzle for their PGP heads (comes on the low-angle nozzle tree)
