Dirty well water
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Jessi Towle, Jun 30, 2012.
  1. Jessi Towle
    Jessi Towle New Member
    Jun 30, 2012
    Hi, we were filling our pool and forgot the water was on. The well ran dry and started pumping up sand. Our water has returned and we are able to shower and use the faucets. However the water is still dirty in the toilets. Is there something we can do to clean them out? How long should this last? Thanks!
  2. PumpDr
    PumpDr Pump Doctor
    Jul 1, 2012
    Well Pump Tech
    Northern NJ
    You should always be careful about overdrawing your well. Use your water sparingly for the next day or so. Eventually it will clear up and the sediment will settle back down to the bottom. You should look into getting yourself a dirt & rust filter. They save big headaches!!
    - Joe
    Pump Doctor LLC
    ___________________________________
    NJ Well Pump Service & Repair
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Yeah you could have overdrawn the well as the Dr says. If so it may clear up in a few days as the water level returns to normal.
    You also could have stirred up the well if the pump was cycling on and off for a long time. If you were just filling the pool with one hose, that maybe the case. If cycling on and off is what stirred up the well, you may need to open up a big pipe or run several hoses at once to pump the well clean.
    If you have a low producing well, you may have overdrawn the well even with only one hose and the pump cycling on and off the entire time. In this case you may still need to pump the well hard to clean it up, and with a low producing well sometimes this takes many attempts.
Similar Threads: Dirty water
Pumps and Tanks Well Forum & Blog. Water is life. Well Water dirty brown after home inspector's flow test Jun 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Help me figure out why my well pumps dirty water May 26, 2016
Pumps and Tanks Well Forum & Blog. Water is life. New well sitting inactive 2 years now running dirty water Feb 17, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Increased pressure with dirty water Aug 16, 2015
Pumps and Tanks Well Forum & Blog. Water is life. water still dirty a week after new pump replacement Aug 30, 2012
