Dirty Water
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Jendo, Jun 9, 2012.
  1. Jendo
    Jendo New Member
    Jun 9, 2012
    Eastern NC
    This is my first post, hope someone here can help/advise me.
    I'm a homeowner with a backyard well intended originally for lawn irrigation. Problem was that the electric pump kept burning out. I recently replaced it (electric pump) with a hand pump. Intention is to simply use well now for an emergency water supply on the property. 1st week, the water was sparkling, clear, odorless, effervescent even.
    I planned to get the water tested, but dropped the ball for a couple of months. Just ordered a test kit, went out to collect a sample and got nasty green smelly water. pumped for an hour and got brown silty water. This water gets much more clear with 24 hours standing, but still does not appear appetizing. Sediment is very fine particulate, I'd guess something like brown baby powder texture. I have not felt of the sediment.
    Was advised to pour several gallons of Clorox into the well. Seemed like a lot to me, so I did .75 gallons, 2 times, several days apart. Pumped a lot of water after letting it sit for several days.
    The well is small diameter, not sure, maybe 1"? Approximately 25' deep.
    I will say, it helped a bit with the odor, but the color and turbidity is even worse now.
    I am in Eastern NC, small town. There has been no ground disturbance, as far as I know.
    Any ideas what could have happened to my nice water?
    Suggestions on what to do?
    I don't see any point in testing such foul water.
    Thanks for any help.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    You probably have a problem with the screen on your well point. You may need to drive a new one.
  4. Jendo
    Jendo New Member
    Jun 9, 2012
    Eastern NC
    Thank you for your help.
    Do you mean drive a new well, or just have a new point/screen installed?
    I looked at information/diagrams on the web. My galvanized pipe is just coming out of the earth, with no concrete base around it. I wonder if water is leaking down the pipe and contributing to the problem?
    I am guessing that wells intended for other than irrigation should be quite a bit deeper?
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    If you can pull the old point, you can replace it with a new one. If not, just move over and drive the new point. Irrigation or not, you only go as deep as there is water.
  6. Jendo
    Jendo New Member
    Jun 9, 2012
    Eastern NC
    Thank you.
Similar Threads: Dirty Water
Pumps and Tanks Well Forum & Blog. Water is life. Well Water dirty brown after home inspector's flow test Jun 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Help me figure out why my well pumps dirty water May 26, 2016
Pumps and Tanks Well Forum & Blog. Water is life. New well sitting inactive 2 years now running dirty water Feb 17, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Increased pressure with dirty water Aug 16, 2015
Pumps and Tanks Well Forum & Blog. Water is life. water still dirty a week after new pump replacement Aug 30, 2012
