dirty water
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jon61, Aug 8, 2005.
  1. jon61
    jon61 New Member
    Aug 8, 2005
    My bathtub in the master bedroom has what appears to be sediment or rust in the water. It is worse when you first turn it on then it appears to be better, but not really. The problem has been going on for a while and I had a new hot water tank installed last week. It does seem to be only at this location
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    rusty pipes
    you probably just got old galvanized pipes
    going to the tub in question,
    if not that then someone used a black nipple
    to hook up to tub spout and it simply leeches a little rusty
    water every time you turn on the faucet.
    some thing like this is going on.
  4. jon61
    jon61 New Member
    Aug 8, 2005
    Thank you for the info, I have noticed that the bad water is just when you first turn it on then it clears up just fine. By the way the water is kind of yellow with junk floating in it.
  5. jon61
    jon61 New Member
    Aug 8, 2005
    What can I do to clean it up?
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Older houses were plumbed with galvanized steel pipes and rust/corrode inside. This not only causes the rusty water like you are experiencing, but the inside diameter of the pipe is squeezed to the point you have flow problems. The solution is to repipe the house. My choice of materials would be copper. You might want to look at Terry's link dealing with piping on the home page.
  7. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    If you have old galvonized water lines, check in the tub access and look for the nipples and ell that the tub spout is screwed to. Replace the old nipples, ell and spout. A little dirt may grow in there between the times that the tub is used.........You may not need to replumb yet.........
Similar Threads: dirty water
Plumbing Forum, Professional & DIY Advice Dishwasher filled with dirty sink water Sep 13, 2016
Plumbing Forum, Professional & DIY Advice Water supply is dirty and bitter Feb 5, 2013
Plumbing Forum, Professional & DIY Advice Dirty water Jan 5, 2012
Plumbing Forum, Professional & DIY Advice Dirty water Oct 21, 2011
Plumbing Forum, Professional & DIY Advice How to flush out dirty water after turning off and on the water main? Sep 8, 2009
