dirty water
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jbhud, Oct 10, 2007.
  1. jbhud
    jbhud New Member
    Feb 15, 2007
    I have a well, submersible pump, pressure tank, etc. and recently, we have been getting brownish water . It has cleared up in the past, but every now and again ( like tonite), it reocurres. any suggestions?
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Mabey install a filter of some kind afteryour pump.
  4. jbhud
    jbhud New Member
    Feb 15, 2007
    i thought about a filter, but i'm wondering why it only happens every so often, not all the time. it's almost a rust color, but i have plastic pipes from the well.
  5. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    sound like you have some iron in your water. Your water can change from rain or lack of rain
  6. jbhud
    jbhud New Member
    Feb 15, 2007
    good point. it usually happens after a rainstorm, but lately it's been dry dry dry.
  7. Gary @ Culligan of NH
    Gary @ Culligan of NH New Member
    Oct 13, 2007
    Start by installing a 10" or 20" Ametek cartridge filter after the pressure tank with a 20 micron filter. It will stop sediment and iron oxides. Well water can change over time, particularly in periods of drought as we had this summer. If the cartridge clogs more than every couple of weeks you may need a backwashing type system.
  8. Gary Slusser
    Retired
    Before you buy anything.... you could have had a slug of rust break loose from inside the drop pipe down the well or underground to the house from the well. Or it could be from IRB (iron reducing bacteria). Or... you could have a problem with dirty water entering the well.
    So tell us more about your water system. Submersible or jet pump? If jet, single or two line? Any water softener etc.? Steel or PVC well casing? Fully cased well with screening in sand and gravel or a rock bore well down through rock?
    How frequently does this dirty water problem happen and how long has it been happening?
  9. jbhud
    jbhud New Member
    Feb 15, 2007
    sorry. been out of town, Gary. It' a submersible, steel casing, and that's all I know about the well . I replaced the pressure tank, and cleaned out all the aerators, which wer full of trash, and the water appears to be nice and clean and plenty of pressure now. I got trash and rust out of the old tank ( a.o.smith ) . I have no water softener or filter. .Pvc from the well casing to the new tank. Galvanized out of the bottom of the tank to a steel "t", then pvc and plastic to the house. The dirty water and low pressure has been an ongoing problem. mostly after a good rain. I was afraid the well was going dry, but now everything seems fine. Should I test the water, and/ or install a filter after the tank?
  10. Gary Slusser
    Retired
    Only if the problem returns but I'm not a fan of 'whole house' disposable cartridge filters. They were never meant to be used POE (point of entry), only POU (point of use).
    This dirty water could have been due to a broken bladder and rusting pressure tank. And steel water lines...
    You might want a hardness test and softener if you have hard water.
Similar Threads: dirty water
Plumbing Forum, Professional & DIY Advice Dishwasher filled with dirty sink water Sep 13, 2016
Plumbing Forum, Professional & DIY Advice Water supply is dirty and bitter Feb 5, 2013
Plumbing Forum, Professional & DIY Advice Dirty water Jan 5, 2012
Plumbing Forum, Professional & DIY Advice Dirty water Oct 21, 2011
Plumbing Forum, Professional & DIY Advice How to flush out dirty water after turning off and on the water main? Sep 8, 2009
