Direction of Pressure Relief Valve
Discussion in 'Boiler Forum' started by Engine1, Jan 16, 2012.
  1. Engine1
    Engine1 New Member
    Jan 13, 2012
    Was looking through the manual for our recently installed, and still uninspected, hot water heating system
    Everything in it, the illustrations for installing the boiler and the written directions, indicate the pressure relief valve should be mounted upright. The manual reads: "3. Orient the manifold with the relief valve on top."
    Ours is mounted into a T from the side, in such a way that it's drain is aimed directly down. Does it matter?
    I thought I'd ask this stupid question only because it's an important safety device.
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    They can be mounted horizontally but they need to be mounted in the top 6" of the boiler water jacket.
  4. Engine1
    Engine1 New Member
    Jan 13, 2012
    I don't know if it's 6" from the top of the water jacket, it's hard to tell where that is with a well insulated cabinet. On the Burnham ES2, the gauge is supposed to be installed at the height of the supply outlet, upright, and the supply outlet is about 14" down from the top of the cabinet.
    Ours is installed at that the same level as the supply outlet, but is horizontal instead of the illustrated vertical. Safe way to do it?
    Again, thanks for answering such a petty question - but then again it's not so petty if the valve is not doing it's function.
  5. Tom Sawyer
    Nov 29, 2010
    Maine
    It should be fine as long as it's in the top of the boiler
  6. Engine1
    Engine1 New Member
    Jan 13, 2012
    Turns out it's not approved for horizontal install, only upright.
    It was not tested in multiple positions, and the sideways pressure fluid dynamics exerted on the spring are supposedly different than if it was upright. Manufacturer said upright, so it will be.
Similar Threads: Direction Pressure
Boiler Forum Replace boiler or new direction? Feb 20, 2012
Boiler Forum Pressure Drop Dec 28, 2016
Boiler Forum Cold water pressure in primary loop rises over time Oct 28, 2016
Boiler Forum Creeping Boiler Pressure! Too High Help! May 4, 2016
Boiler Forum Oil Fired Boiler Exceeds 30 PSI Pressure Mar 4, 2016
