direct-vent gas-fired water heater inspection.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by canton, Mar 5, 2006.
  1. canton
    canton Plumber
    Jul 24, 2005
    Massachusetts
    I'm about to install a new direct vent gas-fired water heater. I'm essentially replacing the old chimney vented which is in a crawl space, this will be in the laundry area and vent out the back of the house 2' from ground. I will also have to run a gas line and water lines about 8' from the old line. What will my inspector be inspecting, and are they're any test involved? In Mass.
  2. Cass
    Cass Plumber
    Nov 12, 2005
    You need to check on local codes as to how far you need to be from windows, doors, ect.
  4. canton
    canton Plumber
    Jul 24, 2005
    Massachusetts
    As far as the window's go, you can't be under and have to be at least 2' away. They also require you to have your vent 2' from the ground, I'm going at least 3' due to snow drifts here in the Northeast. I'm just wondering if I'll have to do a gas test from the point of connection, and for the water I'm wondering the same thing.
  5. Cass
    Cass Plumber
    Nov 12, 2005
    Gas yes, water I don't know about out there. I am from Littleton, MA but have been in Ohio for quite a while. Things have changed a lot since I left.
  6. hj
    wh
    here, you have to have a permit and inspection for almost any revision to a gas line.
Similar Threads: direct-vent gas-fired
Plumbing Forum, Professional & DIY Advice Rudd 80% efficiency gas-fired furnace. Apr 7, 2006
