Direct to stud bathtub install question
Discussion in 'Shower & Bathtub Forum & Blog' started by Radagast, Jul 27, 2007.
  1. Radagast
    Radagast New Member
    Jul 27, 2007
    I'm installing a direct to stud 60" bathtub and have found the studs to be 60.5" apart. This leaves a noticeable .5" gap. What is the correct way to account for this? Should I push the tub up against one side and then extend all the studs on the other side out .5" so they are flush against the tub flange? Won't I then have to increase every stud on that wall by a matching .5" so the drywall lines up correctly?
    Thanks
  2. BAPlumber
    BAPlumber Plumber
    Jul 18, 2007
    Journeyman Plumber, business owner
    Vashon, Washington
    center the tub so there is .25" on each end. When the greenboard, or whatever your using, is installed you'll never notice it. Or, move it to one side and fur out the other for a tight fit, then the entire wall as needed
  4. hj
    tub
    Center the tub.
Similar Threads: Direct stud
Shower & Bathtub Forum & Blog Three Handle Diverter - Changing Shower/Tub Diverter Turn Direction Dec 26, 2015
Shower & Bathtub Forum & Blog Handles turning the wrong direction? Nov 14, 2015
Shower & Bathtub Forum & Blog Claw Foot Tub: Direct Drain Mar 24, 2015
Shower & Bathtub Forum & Blog Tiling directly to Exterior Glue Plywood (EGP) - Tiling Tips Pros and Cons Jun 28, 2013
Shower & Bathtub Forum & Blog Can I tile and/or install a mortar bed directly over polystyrene (solid) insulation? Aug 31, 2010
