Dipping my waters into the *Kaboom* setup
Discussion in 'Toilet Forum discussions' started by chefwong, Oct 19, 2013.
  1. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    Picked up a Kaboom for the new *throne*.
    For the hoses that go into the tube, and or the one that *feeds* the unit from the fill valve, should I cut the tubing as short as needed on both ends to maximize the water ?
    In looking at how I have it', let's say about 6-8" of the extra hose slack + the volume of water in the device.....not sure how much LESS water is being put into the bowl due to this + or whether or not ultimately it will have any effects on the overall flush volume/performance..
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Flush with the Kaboom device in place. Let the tank fill. Note the height of the water in the bowl. Add water to the bowl from a pitcher etc. If the water level does not rise after the added water, the Kaboom is not blocking too much water.
    I doubt that it matters, but there might be a tiny bit more water if you do your trimming on the output side of the cartridge instead of the inlet side, but the difference is probably not measurable.
  4. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    I tried one of those Kaboom things in my Toto Promenade toilet early last year. The tubing size was too small for the toilet setup, but I rigged it anyway. It did NOT work properly, much too much restriction. I wound up using the Kaboom in my older Kohler Memoirs toilet from 2006, where it worked properly. I no longer see those Kaboom cleaners in the stores, by the way. Internet yes. Brick and Mortar stores, no. Church and Dwight still shows it on their website, but could not find any (local anyway) stores in their where to buy search.
  5. Reach4
    Sep 25, 2013
    I use the Flush 'n' Sparkle from Fluidmaster on my old 3.5 gallon toilet. I added a pinch clamp to the hose to cut down on the excessive refill water to save the life of the cartridge. That overfill is probably more a characteristic of the toilet, and your shorter fill and more compete emptying during the flush might make the Flush 'n' Sparkle still underfill for you. I went for the blue cartridge, but I would have used the white bleach cartridge if I were on sewer.
  6. chefwong
    chefwong Member
    Jun 14, 2006
    I did not even knew these things existed until I just so happen to google about Sani Gloss glazing and came across these -inline- cleaners.
    I did not cut the tubing. I just increased the water fill a smigen before the top of the overflow tube just to make up for it.
Similar Threads: Dipping waters
Toilet Forum discussions "Best" Watersense Skirted toilets? Nov 12, 2015
Toilet Forum discussions Toto Aquia and waterspot Aug 30, 2010
Toilet Forum discussions NooB Question: Why are WaterSense toilets so much cheaper than standard toilets? Aug 18, 2010
Toilet Forum discussions Vespin II, CST474CEFG Watersense Toilet Review, comments and pictures. Apr 10, 2010
Toilet Forum discussions Final Specs for Watersense flushing Urinals Oct 15, 2009
