Dip tube removal
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by doonboggle, Feb 12, 2005.
  1. doonboggle
    doonboggle New Member
    Feb 12, 2005
    I want to remove my 'old' dip tube from my 2 year old AmericanPro gas water heater ... for the purpose of installing one with a curve in it ... for clean out purposes.
    In looking at the top, I see a nipple going into the top of the cold water connection for the heater. Once I unscrew the nipple, what do I do then to get the dip tube out? Does it simply unscrew also?
    Thanks
    doon
  2. hj
    dip tube
    Not unless it is part of the pipe you unscrew. If it is not then they usually pull out, not always easily however. The curved dip tube will only "self clean" when a high volume device is used. These days the bathtub and washing machine are about the only two that will make it function. Also, the material disturbed by it, will either settle back to the bottom or enter the hot water piping and eventually flow to the faucets and plug up their aerator screens.
  4. edbreyer
    edbreyer New Member
    Oct 19, 2004
    Chicago
    Flushing out periodically is the best answer?
    Based on the reply about the curved dip tube - it seems like the best maintenance task for a water heater is still to flush out several gallons periodically through the bottom spigot - is this correct?
    I used to do it every couple of months but must confess that I'd forgotten all about in my new house - and it's been three years now -- OOPS!
    I guess I'll do it now while I'm thinking about it - although the deposits may already be solidified at the bottom of the tank.
    I've got another question about anode rods - but I'll post that seperately.
Similar Threads: tube removal
Plumbing Forum, Professional & DIY Advice Woodford tube removal???? Apr 27, 2008
Plumbing Forum, Professional & DIY Advice Tube support liner removal in Shark Bite? Sep 24, 2007
Plumbing Forum, Professional & DIY Advice Overflow tube under sink that seems to no longer exist Jan 17, 2017
Plumbing Forum, Professional & DIY Advice Weird thing with flushomatic toilet; tube connecting pipe to wall Aug 30, 2016
Plumbing Forum, Professional & DIY Advice Triangle Tube Error E03 / E 03 Aug 12, 2016
