Dip in the line or "belly" of my sewer line
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by vsalge, Nov 13, 2008.
  1. vsalge
    vsalge New Member
    Sep 4, 2008
    I recently discovered a dip in the line or "belly" of my sewer line which is in the slab of my house. The house is 5 years old. I've had a plumber run a snake and twice they have confirmed I have about 3 or 4 dips. I've owned this house for 3 years and the previous owner had the same problem. I found this out from the neighbors. This was not disclosed in my closing. I discovered the problem once my toilet backed up into my tub. Do I have any options on who is responsible for paying for repairs? The original plumber is coming to inspect his work and has admitted he originally fixed the same problem 4 years ago but he seems to think, with out looking, that there are other dips now. One the seller should have disclosed this information (Arkansas is the State this is in). Second the plumber should also be responsible. These are my thoughts. Anyone have any suggestions on what I can do to get help pay for the repairs? Or do you have any suggestion on what I should do besides sucking up and paying it all myself? I assume this will end up costing 10 to 20 thousand, which would include cosmetic repairs after the dips are fixed.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    There way too much at stake here to rely on opinions and advice from plumbers and DIYers. While it certainly seems like you should have some recourse, you need to consult with an attorney who can provide you with the legal advice and opinions you need. Our opinions might or might not be valid, but they have not weight or real value toward resolving the problem. Since you very probably have to litigate this in court, the sooner you get an attorney involved the better. Good luck!
  4. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Take a look at your closing papers and you will likely find the seller has signed a statement saying s/he has disclosed everything known at the time of sale. But yes, check with an attorney and take along any warranty papers you might have.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Has the line been inspected with a camera and the bad area located?
  6. vsalge
    vsalge New Member
    Sep 4, 2008
    The seller most definitely did not disclose not one problem and yes he signed saying he has disclosed everything know at the time of the sell. I had the plumber out yesterday that did the repairs originally. He thinks that there are dips but in different places. He is going to bring a camera and snake it and mark the dips. He said when he repaired the dips original that the house was under a warranty from the builder. I’m afraid this is problem is caused from the foundation. My biggest fear is that I have these dips fixed and there will be more later down the road. I think it’s the builders fault and the seller for not disclosing. Bottom line, I’m sure, is I’m SOL.
  7. Redwood
    Dec 15, 2007
    Service Plumber
    Maybe/Maybe not...
    That would be up to a legal expert to decide...
  8. Cass
    Cass Plumber
    Nov 12, 2005
    If the seller moved out of state it will be more costly to go after them legally than the cost of the fix.
  9. vsalge
    vsalge New Member
    Sep 4, 2008
    No the seller is still living in the town I live in. He has a lot of property in this town.
  10. hj
    dips
    First you would have to prove that he actually knew about the dips. The contractor was only liable for one or two years after installation, unless your state has a "hidden defects" provision for up to 10 years. Do you know DEFINITELY that the dips are under the house? If they are outside then that price is probably much too high. If the dips are under the house, then their magnitude would be a factor as to how important it is to eliminate them.
  11. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    I'm confused did your plumber repair the dips for the seller and they came back? What makes you think it is a foundation problem? If it was the dips would be under footings only not along a slab.
    I was an expert witness on a case hear where the seller disclosed that the basement "occasionally got wet", not an adequate description for the 4 to 6' deep floods that the buyer experienced on average, yearly. We took him to court and he settled for about 60 grand. But it cost the buyer about 1/2 that in legal fees.
  12. vsalge
    vsalge New Member
    Sep 4, 2008
    The seller had the plumber fix the dip that was in the slab foundation in 2004. The house was not even a year old. The plumber said he could not find a bill or payment for this service. The plumber and the seller had a few projects other then the house, going on at that time. He wasn’t sure if they just worked it out in trade??? The seller is well know in this town and is always buying and selling property. The plumber thinks the house was still under warranty at the time he fixed the dips in 2004. I bought the house in 9/2005.
    Yes the plumber that originally fixed the dips, was one of the plumbers I’ve had look at this problem. He seems to think the original dips are not the ones that I have now, which I feel could be correct. I will not know for sure until I get them marked.
    I spoke with an attorney and he said to find out as much information I could on my on then come back and talk to him. He said these types of problems can be a gray area. My main issue is that the seller did not disclose the pluming issue at all. If he had I would have made sure I had everything checked first.
    The reason I think this is a foundation problem because I do have a crack in my kitchen floor tile and on one wall in a separate room around the door facing, it’s about 12 inches.
  13. Southern Man
    Jun 27, 2008
    North Carolina
    If the seller paid a plumber to fix it and he did, or claimed that he did, then there would be no reason to disclose it. Although I'm not sure how he could fix the problem without cutting out portions of the slab. You may have to subpoena the plumber's records to find out exactly what he did do. He may be your enemy, not the seller.
    Get him to TV the line and before you pay his bill insist that he provide you the records. Then get your attorney to write him a letter.
    Small cracks in floor tile and around door frames are typically considered normal. Tile can be re-grouted and drywall can be patched very inexpensively.
  14. vsalge
    vsalge New Member
    Sep 4, 2008
    You are correct the slab was cut out, then the dips that had been discovered were fixed and the concrete was filled back in.
    To everyone that has replied, THANK YOU. Any and all correspondence has been helpful and appreciated. It is so helpful to hear what everyone has to say or your options.
    I realize my end result may be that I will just have to pay to have the issues fixed. I just want to know I’ve looked into everything possible. Plus I just want to make sure I do not have to do it again.
  15. Southern Man
    Jun 27, 2008
    North Carolina
    What is the plumber's explanation of how the problem reappeared? Do your neighbors have similar problems? You should probably get the local county building inspector in and see what he says. You may have to hire a local engineer to diagnose the problem. You need to investigate what the problem is so you can fix it once and be done with it.
  16. hj
    dips
    If the building was still under warrantee at the time the first dips were fixed, there should not have been a bill, because it would have been the plumber's responsibility to fix them.
Similar Threads: line belly
Plumbing Forum, Professional & DIY Advice Belly in a 4" Drain Line Jul 6, 2016
Plumbing Forum, Professional & DIY Advice Possible belly in sewage line - need some good opinions Dec 6, 2012
Plumbing Forum, Professional & DIY Advice sink supply lines roughed in wrong spot Tuesday at 1:16 PM
Plumbing Forum, Professional & DIY Advice Our seemingly never ending sewer line under the house problem Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Advice on stack and main line Feb 13, 2017
