Hello Smarter People,
I feel pretty sad that I cant figure this out myself, but I'm not an electrician and I need some help. I replaced a light fixture in my house this past weekend and also decided to put it on a dimmer. Pretty simple and I've done this before, but when I turned the power back on, the light was on even though the switch was in the off position. I turned the power off, switched the 2 wires going into the switch and powered up again. Once again the light is on with switch in the off position! I called the guy that sold me the light and he said I put the switch in upsidedown, so I turned it around and it works like it's supposed to, as far as the light being on when the switch is in the up position, but now my dimmer, which is a slide right next to the switch, operates the opposite of what it should. When I push the dimmer upwards the light should get brighter, but it gets dimmer instead. Do I just need to take down the fixture itself and switch the black and white connections? The wire that came with the light was all one color. Thank you for any guidance you can provide. Have a great day!!
