Brent Clark
Hi all! I'm new to the forums, and a new homeowner as well. I recently purchased a small 1,234 sq-ft ranch house built on a slab, single level. So the house isn't huge by any means.
My problem is the location of the well. First off, the well pump and pressure tank are located 5 feet underground... smack dab in the middle of the "driveway". I use quotes because it isn't paved - just dirt - but it's where the driveway would and should be, and hopefully will be.
Basically, the well is a submersible type (how deep I have no idea) and in this underground "pumphouse" lives the pressure tank, pump switch, and pressure gauge. I want to redo how this has been setup because quite frankly, it's a mess. It's literally a hole in the ground with cinder blocks as the walls, and a 4x4 piece of plywood covering it.
I'm trying to figure out how to tackle this. I know modern wells have the casing above ground due to sanitary reasons, but I wouldn't be able to do that with this as it would interfere with the driveway I would like to pave. I've attached a crude drawing of the setup. Any thoughts? Thanks!
Brent
Brent
