Digital water softener manual regeneration mode?
Discussion in 'Water Softener Forum, Questions and Answers' started by myaroch, Nov 10, 2010.
  1. myaroch
    myaroch New Member
    Nov 9, 2010
    Pa
    I'm interested in a water softener but for the first couple of months when I install, I will need to hook a garden hose up and run a manual regeneration when needed. In the spring I will be able to hook up a drain and run on automatic. Do any of the digital control softeners offer a manual regeneration only mode that will not use their auto feature if set this way?
    Thanks
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I assume the hose is on the drain line? and for some reason you can not run a proper drain at this time?
  4. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    You could always leave it unplugged between regen cycles.. plug it in, start the cycle with the drain going to where you wish and then unplug it when it is done..
  5. hj
    Setting the water hardness to the lowest number, even zero if possible, would delay the automatic regeneration. So if you knew when it would happen, assuming yours tells you how many gallons of water were used, then you could do the manual one ahead of time.
  6. Gary Slusser
    Retired
    The best is to put the discharge into the septic or sewer system.
Similar Threads: Digital water
Water Softener Forum, Questions and Answers Water Test? Also digital Or mech control ? May 3, 2011
Water Softener Forum, Questions and Answers Best On Demand Digital Valve? Mar 8, 2011
Water Softener Forum, Questions and Answers Water Test Results / Treatment Recommendations? Sunday at 5:42 PM
Water Softener Forum, Questions and Answers Kinetico experts - water leaking to drain Mar 16, 2017
Water Softener Forum, Questions and Answers Water softener discharge question............ Mar 11, 2017
