Difficult to remove Tub Basket
Discussion in 'Shower & Bathtub Forum & Blog' started by SKG, Dec 12, 2009.
  1. SKG
    SKG DIY Junior Member
    Dec 12, 2009
    98005
    Hi,
    I am trying to remove my tub basket using a tub basket wrench. I have applied a significant amount of pressure to the wrench and the tub basket has not budged.
    I am wondering....
    How much force is it safe to use on the wrench? Can I hammer it? Should I use some liquid wrench or something on the basket?
    Of course, I do not want to damage the shoe underneath as I don't really want to rip out the whole tub to deal with some minor slow-flow issues.
    For what it's worth, I doubt this tub basket has ever been removed before and this is 1978 construction. Also, the drain line drops a couple of inches and then makes a 90 degree turn to the horizontal and heads out of the tub towards the supply line.
    Thanks in advance for any help that you can offer.
    ~Sid
    If the drain looks like the one below, you may need to pull the "shoe" out with a wire coat hanger.
    I snake from the upper overflow, but the linkage and the stopper need to be pulled out first.
    [​IMG]
  2. jimbo
    jimbo Plumber
    pls. post a pic. of the wrench you are using and what you are using for leverage.
  4. SKG
    Dec 12, 2009
    98005
    Here are the pictures you requested.
    Thanks for you assistance.
    SKG
  5. Terry
    Aug 17, 2004
    That should come out with those tools.
  6. jimbo
    jimbo Plumber
    Nice pics. Since the cross bars in the bottom of the flange have not broken out, you are not using too much torque!
  7. SKG
    Dec 12, 2009
    98005
    Thanks Guys, I will give it another try.
    SKG
  8. hj
    basket
    At that age, the pipe is probably brass. Therefore, do NOT use excessive force or you WILL snap the thread off and have to change the drain somehow, although it probably would not require removing the tub. IF it does not come out with moderate force, you will have to cut it out, and since that process could damage the tub, you might want to call a plumber who has done it many times without creating problems.
Similar Threads: Difficult remove
Shower & Bathtub Forum & Blog Difficult Removal of Old Tub Faucet Valve Jun 30, 2016
Shower & Bathtub Forum & Blog Removing Difficult Tub Spout May 26, 2015
Shower & Bathtub Forum & Blog New shower difficulty finding good company! Sep 15, 2014
Shower & Bathtub Forum & Blog Single Lever Shower Valve Ultra sensitive and difficult to adjust temperature May 16, 2010
Shower & Bathtub Forum & Blog Moving the shower water supply - is it difficult? Jan 16, 2009
