Different standpipe sizes?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mike04gt, Jan 4, 2009.
  1. mike04gt
    mike04gt New Member
    Dec 26, 2008
    Chicago, IL
    Hey All,
    Just wondering if anyone knows if they make a standpipe back seal in any other sizes than 4"???
    My drain opening in the floor is 4.5", but I cannot locate any other larger sizes online or at any of the local plumbing stores.
    Thanks~
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Gonna need a pic so we can see the type of pipe you have.
  4. hj
    seal
    That's because there is no 4 1/2" pipe. The next size above 4" is 5" and it is such a rare beast, that 6" is most likely to be found.
  5. gardner
    gardner DIY Senior Member
    Apr 2, 2007
    Ontario
  6. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    That is 4" ID pipe Go ahead and buy the stand pipe adapter, tighten the screws a bit so its will fit in snug, once you get it in the pipe tighten the screws, the rubber will expand enough to make a seal.
  7. mike04gt
    mike04gt New Member
    Dec 26, 2008
    Chicago, IL
    Yea, its an old cast iron floor drain that measures an odd 4 1/2" opening size.
    Just wanted to make sure it can fit before I buy one, thanks alot!
Similar Threads: Different standpipe
Plumbing Forum, Professional & DIY Advice Different types of boilers Oct 2, 2015
Plumbing Forum, Professional & DIY Advice Back to back toilets; differential height between the two rooms Jul 19, 2015
Plumbing Forum, Professional & DIY Advice Shower head and mixing value on different wall Mar 2, 2015
Plumbing Forum, Professional & DIY Advice Pipe Noise/Vibration; Different catalysts; Don't want to outright call it hammer Dec 24, 2014
Plumbing Forum, Professional & DIY Advice Backflow fitting needed? Is different metals acceptable? Aug 8, 2014
