Dielectric unions and water heaters
Discussion in 'Water Heater Forum, Tanks' started by dx, Dec 18, 2009.
  1. dx
    dx General Contractor
    Jul 4, 2005
    General Contractor
    Michigan
    Two related questions:
    1. We are installing a Bradford White heater for a customer. Looking at their installation manual, they have a picture showing the connections to the nipples, then elbows and short horizontal pieces of pipe, then unions (for both hot and cold). Note that the unions are NOT at the nipples of the heater. And no mention anywhere of dielectric unions. The nipples on the heater look like normal plated steel nipples. Have they found a way to eliminate the need for dielectric unions, or is the installation picture/instructions wrong? I will call them on Monday, but just curious if anyone has seen this before.
    2. As I was buying the dielectric unions for the above job, I noticed that a sharkbite to 3/4" FPT is actually cheaper than the 3/4" dielectric by about 50 cents. Not to mention a lot quicker to install. Can this be used as a dielectric union between steel and copper? The body is brass, and as far as I know brass to steel is fine. And brass to copper also fine.
  2. steelers fan
    steelers fan In the Trades
    Dec 11, 2009
    va
    sharkbites are nice but theyre still plastic guts and you should have 18"-24" of copper(metal) before you transition to any form of plastic
  4. Cass
    Cass Plumber
    Nov 12, 2005
    Sharkbites are brass not plastic...and will work better than dielectric unions as they won't rust shut...
    What do you mean "1. We are installing a Bradford White heater for a customer." who is we...
  5. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    They also make a fitting similar to sharkbites that is plastic. It is also approved for hot water. I wouldn't use them. I don't like snap click plumbing.
    John
  6. hj
    dielectric
    The dielectric is brass, but the length of the brass component is also important because elecltrolysis takes place through the water, not the metal so the further the steel and copper are separated the better. We use a 6" brass nipple, but the Sharkbite would only create a 1/2" separation which would be ineffective.
  7. dx
    Jul 4, 2005
    General Contractor
    Michigan
    Looks to me like a lot more separation than a regular dielectric union. The sharkbite is all brass. The regular dielectric has the steel and copper right next to each other.
    I am sure there are many ways of creating better separation, I'm only asking sharkbite vs. regular steel/brass dielectric union.
  8. dx
    Jul 4, 2005
    General Contractor
    Michigan
    I'm a GC. Like it says in my profile :) My plumber will do the install.
  9. SemiHandyRon
    SemiHandyRon New Member
    Nov 23, 2009
    Editor
    Fairfield, OH
    I'm on the verge of having a BW installed professionally. Do the proper dielectric fittings "come with" the BW heater as a package deal, or do I have to trust the plumber to furnish the right ones himself?
  10. dx
    Jul 4, 2005
    General Contractor
    Michigan
    I don't think I've ever seen a WH come with unions or any other "proper dielectric fittings". Bradford or any other brand.
    No, you don't "have to trust" your plumber, you can just tell him what you want done in specific detail and verify that he did what you asked :) Or, preferably, hire a good plumber and defer to his expertise.
  11. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  12. Cass
    Cass Plumber
    Nov 12, 2005
    Today Most water heaters with 3/4" water ways come with dialetric nipples installed or with the heater...most with 1" water ways don't...
  13. SemiHandyRon
    Nov 23, 2009
    Editor
    Fairfield, OH
    Far be it from a hack like me to tell a licensed plumber how to do his job! As I'm fond of saying, "I know just enough about plumbing to be dangerous." :p
    Thanks, guys.
  14. hj
    dielectric
    The nipples on the heater are "dielectric nipples", and they are no more effective than a dielectric union OR a Sharkbite, for that matter. A dielectric union or nipple DOES have a "break" between the different materials which a Sharkbite does not have. But a Shakbite does also not have the degree of separation which a longer nipple does.
  15. dx
    Jul 4, 2005
    General Contractor
    Michigan
    No the nipple DOES NOT. The nipple is steel. If I screw a copper fitting onto it, the steel and copper will be in direct and extensive contact (the threads) with no break. And they will both be in direct contact with the water.
    Yes, but there is no direct contact between steel and copper. And what is the required "degree of separation"? Is there a mandated minimum length for a brass nipple? Code? Manufacturer's recommendations? How did you decide what is sufficient separation?
  16. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Not touch is not touching....
    Pretty much every hotwater tank installed around here is installed with a brass or copper fitting right off the tank nipples. The tank won't last long enoough for the electrolysis to do enough damage to worry about it.
  17. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    We are seeing the nipples supplied by the heater manufacturers fail before the heater. Take a look at these nipples they are not sch 40 steel nipples.
    John
  18. Redwood
    Dec 15, 2007
    Service Plumber
    Here the water conditions are good enough that the dielectric nipples are sufficient.
    However in some areas the water conditions are poor enough that the dielectric nipples are not enough.
  19. hj
    nipples
    Dielectric nipples have a plastic liner that is supposed to provide the break between the parts of the tank and the pipe in contact WITH the water. WATER is the electrolyte which powers electrolysis, not the mere fact that two materials are contacting each other. You could screw a steel pipe into a copper fitting and set it on your workbench, then come back 100 years later and they would be the exaCTLY same, except dirtier.
  20. SemiHandyRon
    Nov 23, 2009
    Editor
    Fairfield, OH
    What would be in the water for it to be considered "poor" in the sense used here?
  21. dx
    Jul 4, 2005
    General Contractor
    Michigan
    Better look again. The Bradford heater I just bought has steel nipples. No liner on the nipples, just the heat trap retainers.I don't know if the nipples are separated from the rest of the tank and it doesn't matter.
    The nipples are steel and they sit in water. If I connect copper fittings to them, there WILL be galvanic cells and the nipples WILL corrode.
    Edit: Still curious, how did you decide how long of a brass nipple is "sufficient separation"?
Similar Threads: Dielectric unions
Water Heater Forum, Tanks Dielectric union corrosion Mar 2, 2017
Water Heater Forum, Tanks Dielectrics on new HWT Oct 21, 2015
Water Heater Forum, Tanks Replace dielectric nipple with stainless? Oct 18, 2015
Water Heater Forum, Tanks Plastic Sleeve in Dielectric Union Mar 30, 2015
Water Heater Forum, Tanks DiElectric Union or Brass Nipples Mar 15, 2015
