Dielectric union V. Dielectric nipple
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by imadad2, Mar 28, 2005.
  1. imadad2
    imadad2 New Member
    Mar 28, 2005
    Accountant
    Houston
    I installed copper pipe to replace galvenized pipe that had breakdown and leaks. A hot water heater was intsalled without a dielectric union. I went to my local plumbing place and asked for dielectric unions for my pipe. I was given dielectric nipples instead. Are they the same? Or should I have installed the unions instead of nipples. The gentleman I spoke to stated that they are interchangeable and that the nipple is easier to install. I agree with the ease of installation, but wonder if I am still endangering my galvenized pipe by using nipples instead of unions. Any input would be appreciated.
  2. TonyBagadonutz
    TonyBagadonutz Electrician
    Mar 24, 2005
    Electrician
    NJ
    I'm not a plumber (actually I'm an electrician), but I can tell you this:
    A union and a nipple are not the same (ok, that was easy).
    In order to prevent the "galvonic reaction"(oxidation) between the dissimilar metals, you need either a di-electric break(plastic washer or some other non-conductive element) or a metal that does not contribute to the galvonic reaction, such as brass.
    What is the nipple made of?
  4. imadad2
    imadad2 New Member
    Mar 28, 2005
    Accountant
    Houston
    The nipple is made of galvenized pipe and has a rubber/plastic tubing in the center. I used teflon tape on the threads and inserted one end in a female galvenized connection and the other end in a female copper connection. The gentleman I spoke to stated that the water going through the nipple cannot carry a current because of the rubber/plastic insulation inside the nipple. I took him for his word and because the nipple is so much easier to install.
  5. hj
    di-electric
    Since neither is particularly effective, due to the water carrying the current, it does not make a whole lot of difference.
  6. TonyBagadonutz
    Mar 24, 2005
    Electrician
    NJ
    ...that would explain why the big orange box store was selling the di-electric unions for 0.03¢.
  7. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    I don't know much, but I know if you install regular galvanized nipples in a water heater instead of those di-electric nipples between the tank and the copper lines, they will corrode MUCH faster.
    Go with the di-electric nipples.
    Mike
Similar Threads: Dielectric union
Plumbing Forum, Professional & DIY Advice Dielectric union between copper and galvanized pipe Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Dielectric Union Application Apr 6, 2011
Plumbing Forum, Professional & DIY Advice Is dielectric union necessary? Aug 10, 2010
Plumbing Forum, Professional & DIY Advice Dielectric Union Dec 4, 2009
Plumbing Forum, Professional & DIY Advice Tank water heater- dielectric union? heat trap? Nov 23, 2008
