Didn't know about pipe dope, now what?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rafigso, Jan 9, 2013.
  1. rafigso
    rafigso New Member
    Sep 28, 2012
    Greensboro, NC
    I have 2 shower valves and one of them has a one drop at a time leak from the threads. I used Teflon and no dope. I would have used the dope if I had known about it. Short of cutting out the valve and reconnecting everything, is there a sealant I can put around the outside of the threads to seal this drop by drop leak?
    Thanks in advance,
    Rafael
  2. Terry
    Aug 17, 2004
    No. There is nothing that will seal from the outside.
    You will have to cut and redo the joint. It may be that it just wasn't tight enough.
    Options are:
    Tape
    Dope
    Tape and dope
    I would normally just use dope. I don't really like getting too much heat near a joint with tape.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    No, removing it and redoing the leaking fitting is the correct method of repair. I prefer solder/sweating valves in place for this reason.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I think the best way to do this is to sweat the male adapter to the copper pipe before screwing the adapter into the shower valve. Additional soldering can be done to complete the installation without getting the valve too hot.
  6. rafigso
    rafigso New Member
    Sep 28, 2012
    Greensboro, NC
    Thank for the quick reply, took everything out and used the dope, everything is good now.
  7. hj
    I never use tape on metal threads, only for PVC.
  8. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    I have never used tape in my life for anything except wrapping presents
  9. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Pipe dope is illegal in Texas.
  10. Terry
    Aug 17, 2004
    But not in Washington or Colorado!
    Doesn't help me any though. I like micro beers. I don't put anything in my body that won't wash out in 24 hours.
    THC has a half life of 28 days.
  11. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    There is nothing better than a Beer after a hard days work.
    Well, maybe a cigarette after you lay a bunch of pipe, that may come close.
Similar Threads: Didn't pipe
Plumbing Forum, Professional & DIY Advice Didn't know there are different types of tub spout connections Apr 26, 2014
Plumbing Forum, Professional & DIY Advice Plumber didn't include drain venting in new bathroom Aug 6, 2013
Plumbing Forum, Professional & DIY Advice Plumber didn't deburr, should I be worried? Mar 18, 2013
Plumbing Forum, Professional & DIY Advice I used too much flux -- flushing didn't clear it Sep 17, 2009
Plumbing Forum, Professional & DIY Advice New plumber says old plumber didn't know what he was doing Mar 6, 2008
