did i screw the pooch? (painting problem)
Discussion in 'Remodel Forum & Blog' started by number1hag, Mar 20, 2008.
  1. number1hag
    number1hag New Member
    Sep 24, 2007
    surveyors aid for the state of arkansas
    mountain home, ar.
    i am close to the end of a complete rebuild of the wifes bathroom. i was doing some caulking and not paying attention and used silicone caulking. what can i use (paint wise) to cover this? it seems whatever i put on it just beads off. is there anything i can do other than removing all the caulk? boy, i hope it does'nt come down to that. thanks in advance for any help you can give me.
  2. jimbo
    jimbo Plumber
    As a rule, 100% silicone is not paintable. Check with GE, or a good paint store. The only thing I could think of to try is to see if an oil based primer would stick to it.
  4. shag_fu
    shag_fu New Member
    Feb 25, 2008
    Work for contractor
    Illinois
    Try recaulking with a paintable caulk. I recently grabbed a clear caulk(was in the wrong bin, go figger) that wouldn paint and put a white over top and it seamed to work ok. Not sure if the 100%sil will have an effect an the new stuff sticking or not. If that doesnt work then maybe you will have to remove the other stuff.
  5. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    Your probably going to have to remove it. Not much will stick to silicone. Not even silicon.
    Tom
  6. number1hag
    Sep 24, 2007
    mountain home, ar.
    thanks for the coments, i used an oil based primer called ZAP and so far it looks great.
  7. michaelyaffa
    michaelyaffa New Member
    Apr 8, 2008
    Virginia
    i've used zap before as well (i made a similar mistake)... it did the job adequately...
Similar Threads: screw pooch
Remodel Forum & Blog Screws for door hinge Nov 4, 2011
Remodel Forum & Blog Acrylic over oil-based - How badly did I screw up? Sep 10, 2011
Remodel Forum & Blog Screws in Durock...tool late? Aug 5, 2010
Remodel Forum & Blog Best Deck Screws Mar 22, 2008
Remodel Forum & Blog Tough Joist - resists new screws for new subfloor Jul 19, 2007
