Did I overheat the valve when soldering?
Discussion in 'Shower & Bathtub Forum & Blog' started by Davebutch, Aug 25, 2009.
  1. Davebutch
    Davebutch New Member
    May 20, 2009
    Richmond, VA
    I installed a Moen shower valve a few weeks ago. I did all the soldering to the valve on a bench. I removed the cartridge before soldering but didn't remove other parts, like the balancing drums or stops. After roughing in the valve and turning on the water, the stop on the hot side dripped a bit. When I closed the stop, the drip stopped. The water has been on for weeks with the stop closed and I haven't tried it again lately. Could I have damaged an o-ring in the stop when soldering, or is it likely that it just needed to stay wet for a while and will be OK?
  2. hj
    valve
    No way for us to tell. But ANY rubber or plastic parts left in the valve could have been damaged.
  4. Skeeball
    Skeeball New Member
    Aug 29, 2009
    I hope you did your soldering with the valve open
Similar Threads: overheat valve
Shower & Bathtub Forum & Blog Symmons / Temptrol valve, Water comes out of tub spigot when shower is on - New diverter did not fix Yesterday at 7:02 PM
Shower & Bathtub Forum & Blog Old delta shower valve not working Saturday at 6:30 AM
Shower & Bathtub Forum & Blog ProPEX for Shower Valve & Spout Jan 31, 2017
Shower & Bathtub Forum & Blog How to remove broken nipple from shower valve stem Jan 30, 2017
Shower & Bathtub Forum & Blog Is it possible to adjust this particular shower mixing valve? Jan 19, 2017
