Did I finally do it right???
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gmrules, May 30, 2009.
  1. gmrules
    gmrules Member
    Mar 19, 2007
    Computer Networking
    Raleigh NC
    I spoke to a local plumber ans he said that if I came ouot of the wall to a 90 horizontally and then a 90 staright up to sanitary Tee this would be considered a new combination stack and should be ok
    Here is pic of I hope my last attempt. is this correct and will I finally pass code?
    Thanks for ur help and pls be nice if I messed it up AGAIN :D It is straight the camera was on a angle
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Why all the 90's? :confused:
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Sorry, you have an S trap. The problem is the tee in the drain line is too low. The tail piece from the P trap needs to go straight into the tee. The only solution I can see is to cut into the wall, cut the old tee out, and extend the drain pipe upward. Then add a new tee and adapter for the tail piece.
  5. gmrules
    gmrules Member
    Mar 19, 2007
    Computer Networking
    Raleigh NC
    The pip comes out of the wall 2" above the bottom of the cabinet so I needed to raise it up, so I put the first horizontal 90 to allow me more room to tie into the p trap. the second 90 was to raise it up.
    The pipe in the wall comes in horizontal along the wall the same way as the lower pipe I have and then turns up
  6. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    The bottowm of the trap must be below the outlet. You have an S trap there.
  7. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    That santee looks like it's pointed upwards...
  8. Redwood
    Dec 15, 2007
    Service Plumber
    The pipe in the wall...
    Does it run horizontal or, vertical?
  9. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    It aint pretty
    it will work but it is not pretty...
  10. hj
    drain
    If that thing above the tee is an air admittance valve it will work, but so would coming up out of the tee without going sideways first. And just doing what you did, does not make it a combination waste and vent system. To do that would require pipe size changes and other revisions which would have been economically impractical for you.
  11. Cass
    Cass Plumber
    Nov 12, 2005
    the AAV is supposed to be as high as possible...that one is to low...The whole thing is wrong but will probably work for a while...just doen't ever try and snake it...
Similar Threads: finally right
Plumbing Forum, Professional & DIY Advice Finally Replacing My Late 90s No Flow Gerbers And Now Plumbing Questions Have Come Up Sep 20, 2016
Plumbing Forum, Professional & DIY Advice Well Jet Pump - Pressure plummets on use and finally recovers Dec 21, 2015
Plumbing Forum, Professional & DIY Advice How can I add a p-trap to finally resolve stinky laundry room! Oct 4, 2009
Plumbing Forum, Professional & DIY Advice Tub drain not cut into tub right Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Kitchen sink - doing it right Jan 31, 2017
